Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Post Processor Files
Post Processor Files Discuss post processor files here!
Old 05-14-2010, 10:31 PM
MillworkMike is on a distinguished road
AlphaCam V5 post for Mach 3
Hello everybody.... Im looking for a Alphacam V5 postprocessor for mach 3. Any help would be greatly Appreciated. Thanks.
Old 05-16-2010, 04:09 PM
Pierke is on a distinguished road
Question
i'am looking alsofor this!
Somebody??
Pierke
Old 05-18-2010, 12:23 AM
FrankCNC is on a distinguished road
Re: AlphaCam V5 post for Mach 3
I could write one for you if you like as I've written quite a few post for our machines in V5 but never for a Mach machine so I'll need an example program with all the relevant code (i.e. cycles, program start/stop, tool calls, movements G0, G1, G2 etc).
Regards,
Frank
Old 05-18-2010, 06:47 PM
So.... you just need an nc file that ive successfully cut on my machine to go by? Thanks.
Old 05-23-2010, 04:10 AM
Re: Alphacam V5 post for Mach 3
G'Day Mike,
Could you run the attached nc program file Temp.txt (AlphaEDIT opens .txt files) and let me know how it runs on your m/c and what changes need to be made to the post processor.
Import attached .dxf into Alphacam to view material size. All geometries are cut so material possibly needs to be larger (depends on how you hold it).
1st tool 1/8 flat slot drill,
2nd tool 1/8 ballnose needs to have tool radius in tool offset 12 as it uses cutter comp,
max depth of tools is Z-0.15625
Regards,
Frank.
Old 05-23-2010, 04:40 PM
Smile
Hello Frank + Mike,
i'v try the program, but Mach has a problem with the beginning rulers (rem)
When i remove this rulers, the program runs almost to the end, the rule G91 G28 X0 Y0 (machine zero point),gives a problem, he keeps running.
It looks that it works well.
What next?
Thank you,
Pierke
Old 05-25-2010, 05:40 AM
Re: AlphaCam V5 Post for Mach3
Hi Mike & Pierke,
I've attached two basic post processors for the Mach3 controller, one Imperial (Inch) & one Metric, They work fine with all the tool paths I've tried with them in AlphaCam.
Just open them up in AlphaEDIT and then File>Save As Post>Mill or Router.
I've got the post to place an M0 m/c stop at the end of each tool for manual tool change in the router but I've left the M6 auto tool change in the post as I noticed that a tool change request can be set to be ignored in the Mach3 controller (in Configure>Logic) then M6 has no effect.
Don't hesitate to contact me if any changes need to be made or if you need a more advanced post with extra options like User Cycles etc.
Regards,
Frank.
Old 05-25-2010, 05:54 PM
Hello Frank,
The Post is working like a charm!!! Im very happy with it and I really Appreciate your time and help! Thank you, Mike :-]
Old 05-29-2010, 08:30 PM
Smile
Hello Frank,
the postprocessor works geat. Is its possible to make a few changes?
Thank you
Pierke
Old 05-30-2010, 12:18 AM
AlphaCam PostProcessor Mach3
G'Day Pierke,
I'm happy to do whatever changes you want, Let me know what needs to be modified or added.
regards,
Frank.
  #11   Ban this user!
Old 06-03-2010, 06:15 PM
Hello Frank & Pierke...
I was just wondering what kind of changes were made? Thanks.
  #12   Ban this user!
Old 06-04-2010, 01:10 AM
AlphaCam post processor for Mach3
Hi Mike,
No changes made yet, Pierke has not yet replied with changes he want's made.
Frank.
[IMG] code is Off
post processor for mach 3? njitnjau EdgeCam 12 11-23-2010 07:10 PM
Mach 2 Mach 3 Post Processor IntarisiaQ4 Australia, New Zealand Club house 0 10-17-2009 05:50 PM
New Machine Build- Mach 3 post to mastercam x TrickCues575 Post Processor Files 6 05-05-2009 01:18 PM
Need Help!- Mach 3 post from ~9 months ago tikka308 BobCad-Cam 3 05-30-2008 12:32 PM
OneCNC Mach 3 Post TPPJR Screen Layouts, Post Processors & Misc 8 01-11-2006 07:26 PM
