| Post Processor Files Discuss post processor files here! |
Hi mates, I need a post processor compatible with Pro/Engineer 2.0, for a mill machine Mikron. The controller is an Heidenhain TNC 426 conversational. contact me or send it bu mail at: raffaele.leone78@libero.it thank you in advance for help. |
| Hi Leonraffy, May I suggest using your postprocessor for a generic mill output? You may have better luck saving your file as an ISO format and doing a few minor manually edited changes. You can check that the ISO format in your 426 is enabled (if it isn't already) by going into the file editing screen, and then bring up the program manager where the soft key row (2nd row) will allow you to select allowable file types. *.I should be shown. If not, I can send you the parameter procedure to allow the I file extension which will let you load a regular gcode file. This will probably work better than trying to post into a conversational format. Graphics screens, tool nose configuration, datum offsets etc will all still work in ISO on the 426, so don't let that dissuade you. Let me know, Al |
| Thank you for your answer. I tried to make the program in ISO code, but unfortunately there was some problem to run it, and I don't know how to make some manual changes to run the program. I loaded the file on the NC but with no luck. And, I know the conversational language on the NC, but I don't know well ISO code. |
| Post processor - Pro Engineer to heidenhain 155 | UKRobotics | PTC Pro/Manufacture | 13 | 02-14-2012 03:19 PM |
| Need Help!- heidenhain tnc360 conversational post processor | gromit68 | Vectric | 1 | 06-15-2009 03:21 PM |
| Hurco conversational vs. Milltronics conversational | dfpen | HURCO | 10 | 12-29-2008 03:35 PM |
| Heidenhain G-code or conversational? | bigtoad170 | Bridgeport and Hardinge Mills | 8 | 04-12-2008 03:13 PM |
| Newbie- Heidenhain conversational code | a2p4me | General CNC (Mill and Lathe) Control Software (NC) | 2 | 02-26-2008 04:16 PM |
