| Post Processor Files Discuss post processor files here! |
The post for a Centroid controller is MC's MPCENM4. On the first page it says 'Warning: it is generic and is intended for modification to the machine tool requirements and personal preference'. The guy who installed the controller on my BMC30 says he is not experienced in changing post. So, I looked at the file . What in the world do you change. There is a list of variables (numbered questions for Mastercam) at the end of the file. Are these the ones that are to be changed? Are these already taken care of in the setup sheets when running the program? And lastly, for some dumb reason, I get an error when trying to post using the MPCENM4 file. It post fine if I use MPFAN for example. I admit that I am lacking a lot of user experience with this software. Thanks for any help. |
Writing posts is an art in and of itself. It's easy to make minor changes, but like any programming language, it can get very difficult very fast. Word of caution; back up your posts before you start making changes.
__________________ Matt San Diego, Ca ___ o o o_ [l_,[_____], l---L - □lllllll□- ( )_) ( )_)--)_) (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Rekd, Thanks for the help. We have not had a working file from MC on the machine yet. We have just be using the intercon through Centroid. We are 'trading' cad work for some cam with a guy that did some molds for us a couple years ago. So, when I go over ther this afternoon, I will get him to run the post again and copy what the error(s) is. If I remember right, there only appears to be two lines at the bottom of the screen, but there seems to be more than two lines of errors. Maybe they scroll, I don't know right now and will check on it. |
| O.k. Re-ran the post and some stuff scrolled on the bottom two lines of the screen. Selector variable opcode =19.0 out of range for string select. Is there a way we can view all of the info scrolling through this area? It also is still trying to run the post fn. when the error message is displayed. Press escape and then return to get back to normal operation. Any ideas? |
| I ran the same post and got the same error. Code: Processing file with MPCENM4... Selector variable opcode = 19.0 out of range for string select. Postblock label pwrtt I'll check into it some more. Mean time, the file did post OK. You might try loading the program in the controller and (carefully) running it to see what happens.
| I modified my post for centroid (ajax) because the first thing I saw was it was making a z- move at the tool change instead of a z+move. changed it to g28 z0 also made a few other changes with the help of Matt , thanks again Matt Brad
__________________ IF ITS NOT BROKE YOUR NOT TRYING HARD ENOUGH Ashes to ashes , dust to dust , If it wasnt for Harleys the fast lane would rust. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Emco Compact 5 PC...have ???? | Double G | Mini Lathe | 42 | 08-22-2010 07:26 PM |
| Upgrading control hardware - Emco | eDudlik | General CNC (Mill and Lathe) Control Software (NC) | 21 | 12-08-2009 01:52 AM |
| v2xt post | jrrhotrod | Post Processors for MC | 25 | 12-10-2008 06:20 PM |
| MC9 to Mach2 Lathe post? | HogDog | Mach Software (ArtSoft software) | 16 | 10-09-2005 11:28 PM |
| post processor help | jrrhotrod | Post Processor Files | 8 | 01-14-2005 04:45 PM |
