Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Post Processor Files
Post Processor Files Discuss post processor files here!
Old 04-23-2010, 04:42 PM
mabd068 is on a distinguished road
Post processor for HAAS CNC machine
I need to transfer tool offset values from measuring machine (DMG microvision 2) to HAAS CNC milling machine by using flash drive. in order to do so, i need suitable post processor to convert the output file produced by the measuring device. Where can i find the exact post processor??
Ive already use few post processor such as Mill Plus and Heidenhain but id dsnt work.
Old 04-24-2010, 02:29 AM
Superman's Avatar
Superman is on a distinguished road
Ist , you have to find the actual format that the HAAS accepts to update the tool data files and the extension it outputs
Here is an example of an Okuma machine
CNC machine code.....( G1 X0 etc ) ... and uses a .MIN extension on the filename
Tool+Offset data....
Code:
P100 ( Work origin )
Q1X0.00Y0.00Z0.00B0.00
P200 ( tool length )
Q1R0.00
P201 ( tool radius )
Q1R0.00
.... and uses a .SET extension
When you have this info, then find a way for the tool measure m/c to output your tool marshall file in that format.
( I assume you have tools assembled and lengthed offline, ready to go after the current job )
There is 2 methods you could use,
  1. -create a file that is directly up-loaded into the tool data page of the machine
  2. -create a NC file, set as the active program, and run it to update the tool data page using G code to update system parameters ( you could even have a subprogram file - that is called and run at the start of each file, so that you could save it and the program at the end of the run.
Both methods require you to discover the correct format possibilities for the NC machine, not the tool measure
.PM .MM .H are DMG MilPlus and Heidenhain formats and would not be compatable with a HAAS
Old 02-27-2011, 06:56 PM
NCDataServices is on a distinguished road
DMG CMM to HAAS CNC tool offset data transfer app
If you can send me an e-mail with a sample attached data file from the DMG CMM containing the tool offset values I should be able to develop for you an
application that would convert the data format to a file that can be loaded on a flash drive and read as input on the HAAS CNC milling machine.
If you have an example of the HAAS file format it would be helpful, but I have good technical contacts at HAAS to get the information.
Once I receive the file from you I will use it to cretae a statement of work (quote) for the project
Best regards,
Larry
Larry J Jones - Consultant Mfg Engineer
NCData Services - Manufacturing Solutions
NCData@Frontiernet.net
NCData, NC Data, NCData Services, NC Data Services, NC postprocessor services, CNC Software
Office Phone: 1(928)532-8045
Mobile Phone: 1(928)242-8389
[IMG] code is Off
Post processor for HAAS and Fagor machine Namnp2007 Mastercam 7 08-10-2008 09:06 PM
post processor for HAAS vf2 joesimmers BobCad-Cam 3 12-10-2007 08:07 PM
haas sl post processor busted bit BobCad-Cam 0 11-02-2007 09:05 AM
Post Processor for Haas VF biff1212 Post Processor Files 1 02-11-2007 03:00 PM
