Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Post Processor Files
Post Processor Files Discuss post processor files here!
Old 03-25-2010, 10:17 AM
Kaduhn1 is on a distinguished road
Heule chamfer tool post edit
Has anyone ever used a Heule chamfer tool. It chamfers the top and the bottom of a hole in one cycle but it can't be programmed like a drill. What it needs to do is rapid down to part, feed down a little ways to chamfer top. Then rapid down so the top of the cutter(imagine a single cutter that cuts top and bottom) is below the bottom of the hole. Then it feeds back up to chamfer the bottom. Turn spindle off then rapid out of the hole. Easy to program a few holes to do but when multiple holes in a program of different depths it is a pain. Has anyone ever edited the custom drill cycles in the post file and know if you can make it do this cycle or of an easier way than each hole one at a time
Tags
chamfer, heule, tool
[IMG] code is Off
Edit Tool Change Macro Oi-MC dtmtim Fanuc 4 09-21-2007 07:34 AM
Edit Post to use Tool Size Offsets on Controller lorindan Post Processor Files 0 08-11-2007 02:24 PM
Using a 45 deg chamfer tool COPO427 Mastercam 14 01-14-2007 12:28 PM
mazak v5/fanuc 6mb tool changer mastercam post edit wild01 Post Processor Files 1 10-26-2006 08:44 AM
What tool is best? Bevel/Chamfer dneisler General Metalwork Discussion 3 11-29-2005 09:44 AM
