- Need Help!- Mach3 PP ATC
Mach3 PP ATC
Hi
is it possible to change the PP for mach3 ATC mm, so at the end of the program it will
change tool to the First tool used in the G-code
example:
N60 G53 Z0
N70 G40 G49 G80
N80 G54 G17
N90 T8 M06 (First tool)
N100 M03 S3200
N110 G43 H8
N120 G00 X282.2689 Y62.5000
N130 G00 Z35.0000
N140 G00
N150 G00 Z31.0000
N160 G01 Z18.2000 F500.0
N170 G01 X1.7311
N180 G00
N190 G00 Z35.0000
N200 M5
N210 T7 M06 (second Tool)
N220 G43 H7
N230 M3 S12500
N240 G00 X282.2689 Y62.5000
N250 G00 Z35.0000
N260 G00
N270 G00 Z31.0000
N280 G80
N290 M5
N300 G53 Z0
N310 T8 M6 (First Tool)
N320 G54 G00 X1000.0000 Y200.0000
N330 M30
- You may not post replies
- You may not edit your posts
Forum Rules
