Need Help! PROCESSOR FOR MAZAK VERTICAL CENTER SMART 430A
Results 1 to 3 of 3
Thread: PROCESSOR FOR MAZAK VERTICAL CENTER SMART 430A
    Registered slowdigits2's Avatar
    Nov 2014
    canada
    Default PROCESSOR FOR MAZAK VERTICAL CENTER SMART 430A
    Im looking for a POST PROCESSOR FOR MAZAK VERTICAL CENTER SMART 430A EIA/ISO programming to use in Vectric to save tool paths that support I j k arcs and circles to run on the Mazak 430A and that will save the file as a .EIA
    Thanks all
    Nov 2014
    canada
    Default Re: PROCESSOR FOR MAZAK VERTICAL CENTER SMART 430A
    SO I FOUND A PP that will work partly I still need to go in and edit the footer and header to get it to run on the machine, I have upload the PP I use, the file it generates (charpy1) and the file (charpy) after I edit it , also the header I copy and past into it (charphyHeader) what Im wonder is it possible to edit the original PP which is (GCode_arc_inch) to included the Charphyheader) so I do not have to edit the file after saving toolpaths in Vectric I'm hoping someone can explain how to edit the PP or edit it for me
    Thanks all hope someone can help
    Steve
    Attached Files Attached Files
    Member kstrauss's Avatar
    Apr 2013
    Open the PP that mostly works for you in notepad. Then replace some (or all) of the lines following the "begin header" line. For example, the following is the header section that I use for a Tormach under Pathpilot:
    begin HEADER
    "( [TP_FILENAME] )"
    "( [DATE] - [TIME])"
    "( Material Size)"
    "( X= [XLENGTH], Y= [YLENGTH], Z= [ZLENGTH])"
    "([FILE_NOTES])"
    "(Tools in this file: )"
    "([TOOLS_USED])"
    "(Toolpaths in this file"
    "([TOOLPATHS_OUTPUT])"
    "[N]G00G20G17G90G40G49G80"
    "[N]G91.1"
    "[N](Position for tool change)"
    "[N]G30"
    "[N]T[T]M06"
    "[N] (Tool: [TOOLNAME])"
    "[N]G00G43[ZH]H[T]"
    "[N](Mist coolant ON)"
    "[N]M08"
    "[N][S]M03"
    "[N](Toolpath:- [TOOLPATH_NAME])"
    "[N]([TOOLPATH_NOTES])"
    "[N]G94"
    "[N][XH][YH][F]"
    Be certain to edit in NOTEPAD or similar program that doesn't add funny characters to your file (DO NOT USE WORD, FOR EXAMPLE)
