Jake...
It sounds like you have copied a wrong post processor to the "My PostP" folder from the "PostP" folder. Remove the one there, reboot Cut 2D then select from the complete list. Once you know the one you want, COPY it to the My PostP folder.
I have been using cut 2d for a few weeks and when I would save a toolpath it would save it with a "Tap" file extension. Now it will only save it as a "txt" extension , this is for a mach 3, When I hit the pull down tab in the file save, this is the only option listed .
Jake...
Gary Campbell GCnC Control
Servo Control & ATC Retrofits
