Edit Postprocessor
Results 1 to 3 of 3
Thread: Edit Postprocessor
    Nov 2013
    Default Edit Postprocessor
    Hello . I have a problem. I have written about it before but nobody had the right answers to it, so I try again. I use Mach3 and AlphaCam 13. There is not a post processor for Mach3 , so I use " Fanuc 6MB (R arcs - mm ) " but that is to be corrected : prior comments will be put a " ' " but Mach3 requires comments in between "()" How do I change it ? Sincerely . Ib
    Member Maroslav4's Avatar
    Apr 2015
    Czech Republic
    Default Re: Edit Postprocessor
    I think that you mean comment which are generate automatically for Alphacam. Something like
    '(OP 1 SPIRALNI HRUBOVANI NASTROJ 4 FLAT - 50MM)
    '(EFEKTIVNI PRUMER 50, PRIDAVEK 10)...
    Try switch $540 from 0 to 1. Then this comment wil be disable.
    Nov 2013
    Thank you for your response. Yes it is the automatic generated AlphaCam files it comes . I will use your solution if no other option , but maybe I'll make a program that converts the file to the right including comments . Yours sincerely . Ib
Edit Postprocessor
Edit Postprocessor
