Nickkinsman,
After taking a look at the post processor, it does not appear we have an area in which this can be changed. What I went ahead and did was created a script to output the value with a letter designation that can be changed by you. To implement this into your post processor, the first thing that will need to be done is update the version at the top of the post to 10.0. Then you will past this code into program block one, which if it does not exist in your post processor, you will create a block number 2001. Then underneath this, you will past the script that is below. Then change the finish_number_of_cuts to program_block_1. You can change letter designation easily by changing the D in the parenthesis to whatever letter you want output.
Script:
Dim finishPass
finishPass = CALL Lathe_GetFinishNumberOfCuts()
Lathe_SetReturnString("D"&finishPass&"")
