- Newbie- LNC M520H , need a post processor , Please help
Many thanks to all ,
Please help, LNC M520H controller
A couple months ago I got a used CNC Mill , made in 2008 , It's a little bigger than a Bridgeport , A nice machine ,A good deal ? I can run programs that are in it ,4 or 5 lines , at the most , I talked to the last operator , used very little , write and run with one hand on the e stop , never cad cam or any file transfer, it's a quite machine , low use hours. I had communication problem , but now have Ethernet connection , works fine but my programs , from fusion 360 have not worked yet , tried a haas post processor , and 2 others , I can get them to start to run after I delete the first 3 or 4 lines, and run out of X travel when I hit cycle start ? and it will graph on the machine ,this wild X travel shows on the graph on the machine screen , but has wild x travel to start , I e stop it , before it hurts anything. Any idea's , suggestion's ? post processors to try ? I am also wondering about home , zero g54 etc , put the graph show it go , then comes back to machine ?
Thanks to everyone reading this and those that reply
Thanks Daniel
- You may not post replies
- You may not edit your posts
Forum Rules
