Results 1 to 3 of 3
Thread: Sign Foam Board
    May 2010
    Question Sign Foam Board
    I've been making signs for a few years now, and I'm in the process of building my first CNC machine. I'm hoping it'll be done in a week or two, which brings me to this question.
    Is there sign foam board sold that has a colored outer core and a white inner core? I have a gig to make signs for a golf course, nothing fancy, but they want green and white signs. I'm thinking this would be a huge time saver if I used a v carved look. No painting.... tada!
    Has anyone ever worked or found something like this? Any help would be appreciated.
    Thanks.
    Sep 2006
    Sweden
    Wouldn't you be much better off buying a vinyl cutter and just apply green cut vinyl to white PVC foamboard?
    Jun 2009
    Quote Originally Posted by KnotsAboutWood View Post
    Thanks.
    Paint the board the color you want first, then use a vinyl film to cover it. Then cut. Then paint the revealed core in the core color you want, then peel back the vinyl to reveal the surface color again. The vinyl is cut at the same time as the sign, and acts as a mask for the second coat.
  1. High Density Urethane Foam (A.K.A. Butter-board)
    By rigo430 in forum General Material Machining Solutions
    Last Post: 09-10-2010, 02:06 PM
  2. Source for sign board ?
    By SScnc in forum General Signmaking Topics
    Last Post: 06-03-2010, 03:44 PM
  3. Need Help!- Foam Board Problem
    By oakleigh in forum CNC-Zone
    Last Post: 10-24-2008, 12:42 PM
  4. Need Help!- Sign Foam 3
    By cwells in forum Want To Buy...Need help!
    Last Post: 02-13-2008, 07:51 PM
  5. pvc foam board feeds
    By DEW in forum WoodWorking
    Last Post: 10-03-2007, 01:17 PM
