Page 3 of 4 FirstFirst 1234 LastLast
Results 25 to 36 of 48
Thread: Here is a couple of signs
  1. #25
    Registered Pplug's Avatar
    Jan 2007
    A few more!
    Oops I posted a repeat!
    Attached Thumbnails Attached Thumbnails Here is a couple of signs-image-314369036.jpg   Here is a couple of signs-image-3486520517.jpg   Here is a couple of signs-image-2357222793.jpg
    [url]Http://www.glenspeymillworks.com[/url] *Techno LC4896 - 2.2Kw Water Cooled Spindle | *Moving Table Mill from an Omis 3 CMM, 500Lb granite base, Hitachi router, Mach3
  2. #26
    May 2006
    One of the big advantages for those of us with routers, we can pocket, mask, and paint as seperate pieces. I often us HP Vinyl letters, applied on panels. This also speeds up the finising process.
    Attached Thumbnails Attached Thumbnails Here is a couple of signs-pecan_valley_2.jpg
  3. #27
    *Registered User*
    May 2009
    That's a beautiful job Joe
    What is HP Vinyl letters?
  4. #28
    May 2006
    Nicolas,
    That is high performance vinyl which is cut in a plotter.
    If I was doing this job today I'd use Dibond or PVC for the letteering. But that was well over fifteen years ago and the materials weren't available. The major point being, with a router you aren't locked into having to paint the sign as a single piece. Most of my signs now are made in several pieces. Each being painted seperately and attached.
    Joe Crumley
    www.normansignco.com
    Attached Thumbnails Attached Thumbnails Here is a couple of signs-pecan_village_3.jpg
  • #29
    Aug 2009
    USA Michigan
    what kind of wood are you using?
    kevin
  • #30
    *Registered User*
    May 2009
    Thank you Joe, you are a real artist. I looked at your site and that’s an excellent job you did.
    I will have a look in the stores and see what I can find. It will be an interesting experience
  • #31
    *Registered User*
    May 2009
    My local store carries various thicknesses of self adhesive vinyl rolls
    I would cut the vinyl with my CNC router using 1/8”, 1/16” or 1/32” one flute bits.
    Is there any recommended vinyl thickness there?
  • #32
    Jan 2007
    Why not use a drag knife on your cnc? You could make or buy a holder easily and attach it to the spindle. Just don't turn the spindle on!
  • #33
    *Registered User*
    May 2009
    Quote Originally Posted by Pplug View Post
    That's an option I'm working on but I also read that some use the bit as a cutter.
    So the question remains: is there a specific vinyl thickness guide line for cutting either with a knife or a bit
  • #34
    Jan 2007
    You should ask that in the right forum. This one gets buried and fewer people see it. I think my knives can dig about 1/16" on my cnc. I haven't tried it yet.
  • #35
    *Registered User*
    May 2009
    No problem Pplug, dont know which one is the right forum so I will experiment and find out which vinyl gives the best results. I guess there must be other variables involved besides the vinyl thickness like plunge speed, router RPM, feed rate etc.
  • #36
    Oct 2010
    When you say vinyl, do you mean like peel off vinyl we normally run through a plotter? Because I can't see a rotating bit working on that it will wrap up and gum up a bit quickly. A drag knife really is the right way to do that on a flat bed CNC machine.
  • Page 3 of 4 FirstFirst 1234 LastLast
    1. painting vcarved signs
      By cxixer in forum WoodWorking
      Last Post: 08-30-2011, 10:47 AM
    2. Need Help!- Carving Signs
      By Sam A in forum BobCad-Cam
      Last Post: 05-04-2008, 10:01 PM
    3. Painting wooden signs?
      By abomb55076 in forum WoodWorking
      Last Post: 08-07-2007, 11:39 PM
    4. wood signs
      By Pugster in forum WoodWorking
      Last Post: 07-08-2006, 12:21 AM
    5. Top Ten Signs
      By wms in forum CNCzone Club House
      Last Post: 06-21-2003, 08:04 PM
