Page 2 of 4 FirstFirst 1234 LastLast
Results 13 to 24 of 48
Thread: Here is a couple of signs
  1. #13
    Registered Pplug's Avatar
    Jan 2007
    Most of the time I just paint the tops of the letters. I am working on a method using a vinyl cutter to create a mask that would let me spraypaint the sides as well without hitting the background. I haven't tried it yet.
    [url]Http://www.glenspeymillworks.com[/url] *Techno LC4896 - 2.2Kw Water Cooled Spindle | *Moving Table Mill from an Omis 3 CMM, 500Lb granite base, Hitachi router, Mach3
  2. #14
    Oct 2010
    I'm new to routers, but I use a laser for my signs. For 2 colors I'll paint the raw material, then mask it with vinyl sign transfer tape, engrave it, spray it with color #2 then unmask the material.
  3. #15
    *Registered User*
    May 2009
    Quote Originally Posted by bpoulin View Post
    I didn't know about this vinyl sign transfer tape. sounds a good idea
  4. #16
    Registered cheetahcnc's Avatar
    Oct 2007
    Real nice, amazing what fantastic work lies beneath ordinary wood
  • #17
    Oct 2010
    Here is a single color masked then I just burned the wood with the laser. Here is where I get my masking Sign Warehouse And if that doesn't work they have vinyls specifically for spray masking, or sandblast masking I haven't experimented with any of these and a rotary cutter, it might take some experimentation.
  • #18
    *Registered User*
    May 2009
    Hey bpoulin, that’s the best info I got so far, thanks for the info
    When you say “I just burned the wood with the laser” what guides the laser? I mean do you have the gcode or another code for this sign on your laser?
  • #19
    Oct 2010
    It's a Chinese CNC laser engraver, 1200x800mm cutting area. Check out the laser engravers forum here on CNCzone.
  • #20
    *Registered User*
    May 2009
    Sorry bpoulin, I know about the Chinese Laser Engravers. What I dont know is how the engraver knows where to burn the wood on that sign.
  • #21
    Oct 2010
    Sorry I misunderstood you. It's all in the software used to run it. I use vector art, but you can use grayscale bitmap images as well. It has to be a true black and white image the laser is pulsed on for black areas and off for white, and it runs like a printer back and forth across the image, and at the end of one line it will step up one line and repeat. When watching it, it looks like a giant inkjet printer. The machine uses a .mol file which I think is a machine operating language file. Probably similar to G-code.
  • #22
    *Registered User*
    May 2009
    Now I get it bpoulin, much appreciate your time
    I knew about the Lasers but I didn't know how they work and now I got it
    Thanks again
  • #23
    Oct 2010
    No problem, any more questions drop me a line. poulinphotography@gmail.com
  • #24
    May 2006
    GLEN,
    Excellent work my friend.
    I always enjoy seeing your signs. Please keep posting.
    Joe Crumley
    Norman Sign Company, Norman, Oklahoma, SandBlasted Signs, Sign Painter, Redwood Signs
    Attached Thumbnails Attached Thumbnails Here is a couple of signs-galyean2.jpg
  • Page 2 of 4 FirstFirst 1234 LastLast
    1. painting vcarved signs
      By cxixer in forum WoodWorking
      Last Post: 08-30-2011, 10:47 AM
    2. Need Help!- Carving Signs
      By Sam A in forum BobCad-Cam
      Last Post: 05-04-2008, 10:01 PM
    3. Painting wooden signs?
      By abomb55076 in forum WoodWorking
      Last Post: 08-07-2007, 11:39 PM
    4. wood signs
      By Pugster in forum WoodWorking
      Last Post: 07-08-2006, 12:21 AM
    5. Top Ten Signs
      By wms in forum CNCzone Club House
      Last Post: 06-21-2003, 08:04 PM
