Alan,
Your off to a good start, everything mechanically looks like it will perform great. What gear ratio did you select? Your are correct it is a very similar design that I just finished constructing... Are you building your waterbed out of alum. / steel? What type of plasma unit are you going to use on the machine?
LinkBack URL
About LinkBacks
