Maybe you should list what THC you are using. Campbell Designs etc.
how do you know when the thc rate is perfect setting?
when i had it at 30 it does bob up and down and now its at 20 it seems to work good but i wonder maybe it should be more finer number like 22 or 24
is there any way to caculate and find out what percentage it should be setup at?
specs about my machine..
for my z axis its 10 000 steps per rev
If it works.....Don't fix it!
I use CandCNC setup
