Page 1 of 25 123411 ... LastLast
Results 1 to 12 of 300
Thread: Started building new 5 X 10 table today
    Registered millman52's Avatar
    Jan 2006
    USA , West Virginia
    Started on some of the smaller parts I have already created CAD drawings of. I don't have everything I need gathered up for the build but though I'd try & get a few things out of the way.
    Pictured below is a bearing truck I am going to use on the X axis. Have more to go on it but at least it's a start.
    The bearings I used for this are high precision double row left over from another job.
    Attached Thumbnails Attached Thumbnails Started building new 5 X 10 table today-gantry_runner_1.jpg
    If it works.....Don't fix it!
    Registered santiago lisboa's Avatar
    Sep 2006
    puerto rico
    Smile I will follow you
    Hi:
    I will follow your project. I will like to build one. Fisrt I will see how it goes.
    ATT
    chakill
    Jan 2006
    USA , West Virginia
    Quote Originally Posted by santiago lisboa View Post
    Hi:
    ATT
    chakill
    I am making enough CAD drawings to get myself through this build without having to backtrack & do over. At least keep it to a minimum. I am also keeping a list of materials purchased.
    It will by no means be a complete set of plans or parts list. But I will of course be most willing to share any plans or ideas I might have.
    And as always, I'm open to suggestions.
    Not much building going on right now. Mostly gathering up parts, Ebay etc. I have ordered & received a large part of the steel, tubing, etc. for my basic table frame. I'm wanting to hold off on the table itself till I have lots of the smaller components, like the piece pictured above, built. I don't want to commit enough of my floor space for the table to just sit there in my way while I machine & fit all these smaller parts together.
    Jan 2006
    USA , West Virginia
    I have my stepper motor sizes calculated & a few other things. Hoping to get started on motor mounts & primary belt reductions soon. I need to get notched belts & pulleys plus some bearings in. & I'll begin construction on those
    Gold Member txcowdog's Avatar
    May 2005
    Why not build the Mechmate? The hard work is already done and there is a support forum.
    Jan 2006
    USA , West Virginia
    Looked at the Mechmate, As with most other plans & kits out there there are things I like & things I dislike about them. So I decided to "roll my own".
    In my case the table will most likely be used daily & will be used by more than 1 person. If I were the only one using it I could pop rivet tin together & make it last for years. If the hired help uses it It needs to be built & precision parts protected to the point you could park a truck on it & use it for a grease rack....
    May 2005
    I understand what you mean. I used to buy the finest tools because I wanted my guys to have the best allowing them to do excellent work but they destroyed everything I ever brought into the shop. Now I buy adequate tools and they still do excellent work but I save a bundle when they tear up the tools.
    Jan 2006
    USA , West Virginia
    X rail mount
    I am using round rail 1 1/8" 1045 CRR for my "X" axis. Below is a picture of 1/4" strap iron I have drilled plug weld holes & 5-40 tapped holes for set screws to clamp the rail in.
    This will allow me to rotate the round rail or replace it if wear develops where the bearings contact it.
    Attached Thumbnails Attached Thumbnails Started building new 5 X 10 table today-cnc_rail_clamp_drawing.jpg   Started building new 5 X 10 table today-cnc_rail_clamp_002.jpg
    Registered massajamesb's Avatar
    Mar 2006
    Looks good! Keep it going and don't let the weather slow you down!
    "If the women don't find you handsome, they should at least find you handy"
    -RedGreen show.
    Jan 2006
    USA , West Virginia
    Rail-Beam assembly
    Managed to get one of my beams & rail fabricated up. On to the other side now.
    Attached Thumbnails Attached Thumbnails Started building new 5 X 10 table today-cnc_beam_rail_assembly_001.jpg   Started building new 5 X 10 table today-cnc_beam_rail_assembly_002.jpg   Started building new 5 X 10 table today-cnc_beam_rail_assembly_003.jpg   Started building new 5 X 10 table today-cnc_beam_rail_assembly_004.jpg
    Registered Weldtutor's Avatar
    Oct 2005
    Arrow Good Start!
    Quote Originally Posted by millman52 View Post
    Congratulations & thanks for the photos!
    It looks as if you are off to a good start!
    That beam & rail looks just like your drawing a couple posts back.
    The Hobart MG in the last photo, is like one that I have fed miles of wire with.
    Jan 2006
    USA , West Virginia
    Quote Originally Posted by Weldtutor View Post
    That old rascal has the best arc of anything in my shop. In fact it may be the best MIG welding machine I have ever used. If it just wasn't so noisy LOL. I mainly use it anymore as a back up machine. I ran it for about a week & 1/2 recently. The fan motor went out in my 400A Linde (another piece of history). ESAB didn't have a replacement on the shelf. so I had to improvise. Thank goodness for Ebay.....
  • Page 1 of 25 123411 ... LastLast
    1. Not sure I'm ready for this - I've started building!
      By Mike F in forum CNC Wood Router Project Log
      Last Post: 02-26-2011, 10:26 PM
    2. Started building at last!
      By The Wizard in forum CNC Wood Router Project Log
      Last Post: 09-05-2007, 04:16 AM
    3. just started today
      By EMCLLC in forum JGRO Router Table Design
      Last Post: 01-22-2007, 04:34 PM
    4. Started first CNC today
      By TopSpin80 in forum DIY CNC Router Table Machines
      Last Post: 02-03-2004, 09:01 AM
    5. I finally started building!
      By chuckknigh in forum DIY CNC Router Table Machines
      Last Post: 07-10-2003, 09:12 AM
