Page 1 of 2 12 LastLast
Results 1 to 12 of 19
Thread: 4x8 capacity Oxy-fuel table
    Feb 2012
    Hi everyone,
    I've lurked here for a while reading countless threads and attempted putting some of the knowledge I've picked up to use building this table. I decided it was time that I had this capability in-house and went ahead with this project. I've got a fair bit of machining and fabricating experience but this is my first foray into the world of CNC.
    Travel on this machine is 102" x 54". X and Y motors are 570 oz/in with 8060 drives from Keling. Powered Z will come a little later. Racks and pinions came from Applied Industrial. I tried to keep costs down and I think my total is only at about 2500.
    I'll go ahead ahead and bore everyone with photos now...
    Thanks for looking!
    Marv
    Feb 2012
    I'll start with the basic frame. Main rails are 3x3 box tube with 2x2 spreaders. One inch diam adjustable leveling feet. 6203 bearings on eccentric adjusters.
    Attached Thumbnails Attached Thumbnails 4x8 capacity Oxy-fuel table-img_2294.jpg   4x8 capacity Oxy-fuel table-img_2295.jpg   4x8 capacity Oxy-fuel table-img_2298.jpg   4x8 capacity Oxy-fuel table-img_2301.jpg
    Feb 2012
    Here are some pics of the Y-car and the eccentric pinion shaft adjusters. Y-car rides on 6000 and 6203 bearings. 15 tooth 12 diam pitch pinions.
    Attached Thumbnails Attached Thumbnails 4x8 capacity Oxy-fuel table-img_2303.jpg   4x8 capacity Oxy-fuel table-img_2304.jpg   4x8 capacity Oxy-fuel table-img_2305.jpg   4x8 capacity Oxy-fuel table-img_2306.jpg
    Feb 2012
    Some pics of machining pulleys for the HTD 5mm x 15mm belts. 60 tooth is 6061, 18 tooth is stressproof steel. The small sprocket was then heat shrunk onto a hub with one integral flange and outer flange staked on.
    Attached Thumbnails Attached Thumbnails 4x8 capacity Oxy-fuel table-img_2312.jpg   4x8 capacity Oxy-fuel table-img_2313.jpg   4x8 capacity Oxy-fuel table-img_2314.jpg   4x8 capacity Oxy-fuel table-img_2318.jpg
    4x8 capacity Oxy-fuel table-img_2322.jpg   4x8 capacity Oxy-fuel table-img_2323.jpg
    Feb 2012
    Gantry and Y-car.
    Attached Thumbnails Attached Thumbnails 4x8 capacity Oxy-fuel table-img_2325.jpg   4x8 capacity Oxy-fuel table-img_2327.jpg   4x8 capacity Oxy-fuel table-img_2330.jpg   4x8 capacity Oxy-fuel table-img_2331.jpg
    4x8 capacity Oxy-fuel table-img_2332.jpg   4x8 capacity Oxy-fuel table-img_2333.jpg
    Feb 2012
    Paint job (John Deere construction yellow!) and reassembly. I'll grab some more photos and post again soon.
    Marv
    Attached Thumbnails Attached Thumbnails 4x8 capacity Oxy-fuel table-img_2335.jpg   4x8 capacity Oxy-fuel table-img_2337.jpg   4x8 capacity Oxy-fuel table-img_2338.jpg   4x8 capacity Oxy-fuel table-img_2339.jpg
    4x8 capacity Oxy-fuel table-img_2340.jpg   4x8 capacity Oxy-fuel table-img_2342.jpg
    Feb 2012
    A few more pics of the pressurized control box with Dell 280 built in and the low buck cable carrier setup. I didn't have any luck sourcing any Igus type carrier locally and ran out of time.
    Attached Thumbnails Attached Thumbnails 4x8 capacity Oxy-fuel table-img_2346.jpg   4x8 capacity Oxy-fuel table-img_2348.jpg   4x8 capacity Oxy-fuel table-img_2352.jpg   4x8 capacity Oxy-fuel table-img_2353.jpg
    Feb 2012
    A few more showing slat details, Y-car and torch holder, gantry drive, and it sitting in place.
    I did a few test runs on some lighter material and with the exception of me needing to learn a few things about Mach3 and Sheetcam, everything seems to work great.
    It is easily capable of rapids of over 1000 in/min and will accelerate in excess of 200 in/sec^2. Despite being single drive, the gantry is very rigid because of the long X-car bearing spacing and light weight of the gantry itself.
    Come on guys, I'm looking for some criticism or some tips... anything!
    Marv
    Attached Thumbnails Attached Thumbnails 4x8 capacity Oxy-fuel table-img_2349.jpg   4x8 capacity Oxy-fuel table-img_2350.jpg   4x8 capacity Oxy-fuel table-img_2351.jpg   4x8 capacity Oxy-fuel table-img_2355.jpg
    Jan 2011
    No criticism or tips from me....just wondering what your "cable carriers" are made from? Looks like rubber hose, or something similar?
    Carl
    Registered Teknition's Avatar
    Dec 2005
    Pretty impressive build. You've got some serious fab skills and think outside the box. Im glad you shared making the pulleys for the belt reduction units, that was one of my favorite parts. Very creative cable carriers as well. Only 2 things come to mind that I would have done differently than you. I would have ran the bearings on CRS bar instead of the rectangular tube just for tollerance issues and I would have extended the rail on the short side of the X axis so the short side Y leg could be straight. Seeing it on an angle like that looks a little strange for some reason although I understand why you did it, so the gantry could park out of the way.
    Brad
    Feb 2012
    @ I Lean,
    The larger ones running down the X axis are just 1/2" (5/8" OD) pex pipe. The smaller ones across the gantry are 1/2" nylon air brake hose. I machined spreaders that clamp them together every foot or so out of some UHMW.
    They seem to be doing the job and haven't tangled themselves up yet
    Ran the first paying job tonight cutting some 5/8" A36. Used size #1 Airco style #263 tip burning propane and cut oxy @ 40 psi and 16 ipm. Pierced 7/8 holes with 35 seconds preheat and 22 ipm. Very impressed with hole and cut quality. Lost cut once when at 18 ipm probably 2 feet into the cut, so I just cut the speed to 16 and tried to be more patient. I think I could have upped the speed on the holes a fair bit, but most of the slugs dropped out on their own anyway, so I left it alone for this job.
    Feb 2012
    @ Teknition,
    Thanks for the compliments!
    I totally agree with you on the CRS vs tube issue. I was in a huge rush as usual and the CRS would have been a bit difficult to get around here. I did take a micrometer with me to the steel supplier and managed to find a length that was exceptionally uniform. I welded carefully and heat shrunk to counteract weld shrinkage in many areas. I also "balanced" alot of the welds to minimize distortion.
    I realized after the fact that the angle leg is still dangerously close when loading full sheets and it would have been better to do it as you suggested. Just trying to save a little space, and it didn't really work out that way. Oh well
    I did drill a couple dud pulley blanks because the holes are NOT on the pitch circle like some folks on the net claim they are. I finally dug up the right dimensions for the HTD profile and they turned out very well. If anyone is needing the specs just ask. I originally ordered the small flanged ones because of the extra trouble of building the flanges and the cost was low, but after waiting two weeks for them, it turned out that they shipped AT profile instead of HTD I didn't have time to wait so I just made them too.
  • Page 1 of 2 12 LastLast
    1. Rotary Table Capacity
      By AMCTony in forum Haas Mills
      Last Post: 12-04-2010, 08:09 PM
    2. Need Help!- CNC Oxy Fuel Help
      By Gawker in forum Torchmate
      Last Post: 12-23-2008, 06:43 PM
    3. Table capacity?
      By cwm9 in forum Taig Mills & Lathes
      Last Post: 12-14-2008, 04:08 AM
    4. Weight capacity of Tree 2UV table
      By midlf in forum Tree
      Last Post: 10-24-2008, 11:32 PM
    5. EPA fuel standards
      By cdlenterprises in forum Environmental & Alternate Energy
      Last Post: 04-16-2007, 08:38 PM
