Page 1 of 5 1234 ... LastLast
Results 1 to 12 of 59
Thread: I-Channel CNC Egyptian plasma
    Registered Islam's Avatar
    Jun 2009
    Egypt
    Hi all,
    Till now nobody knows clearly how ancient Egyptians could engrave their alphabetic and drawings on their temples walls and obelisk by such accuracy.
    Also me don’t know, however I think that my grandparents had invented a special router - not necessarily to be cnc - which had been used for their engravings on the very hard rocks.
    My name is Islam from Cairo, after I have been lurking in this forum for some months, gathering information and working on parts lists, I put my first design and laser cut parts drawing of my cnc plasma cutting machine by using the sheet metal Autodesk inventor and started the implementation of my project.
    My design is based on the (I) channel as the gantry rail without need to use linear bearing or gauge plate taking into account the precision conservation as we shall see together.
    Water table will be a standalone table carrying a standalone water tank.
    The machine designed to be able to be dismantled into parts and pieces which are easy to be carried by man ,delivered in a small truck and installed in any place without need a fork lift or a wide door.
    Firstly I would like to thank in advance cnc zone for providing such a wonderful resource.
    Hers my progress so far, comments and suggestions will be appreciated.
    Attached Thumbnails Attached Thumbnails I-Channel CNC Egyptian plasma-view-1.jpg   I-Channel CNC Egyptian plasma-view-2.jpg   I-Channel CNC Egyptian plasma-view-3.jpg
    Jun 2009
    Egypt
    Here is the Gantry an Z axis holder.
    Attached Thumbnails Attached Thumbnails I-Channel CNC Egyptian plasma-view-4.jpg   I-Channel CNC Egyptian plasma-z_axis_module.jpg
    Jun 2009
    Egypt
    The chasis progress.
    I used a flat board, DIY right iron welded angles and G & F clamps to get an accurate and precise chasis as illustrated in the photos.
    These are the photos of the leser cut parts of my DXF design.
    Attached Thumbnails Attached Thumbnails I-Channel CNC Egyptian plasma-012.jpg   I-Channel CNC Egyptian plasma-003.jpg   I-Channel CNC Egyptian plasma-002.jpg
    Jun 2009
    Egypt
    100 x 100 mm I channel
    30 x 50 mm square beam
    40 x 80 mm C channel
    Attached Thumbnails Attached Thumbnails I-Channel CNC Egyptian plasma-phot0038.jpg   I-Channel CNC Egyptian plasma-phot0039.jpg
    Jun 2009
    Egypt
    Machine chasis with stanalnoe water table during progress.
    Attached Thumbnails Attached Thumbnails I-Channel CNC Egyptian plasma-010.jpg   I-Channel CNC Egyptian plasma-011.jpg   I-Channel CNC Egyptian plasma-012.jpg
    Jun 2009
    Egypt
    Side weldings on the flat board using G clamps.
    I Channels preciseness and rightness.
    Attached Thumbnails Attached Thumbnails I-Channel CNC Egyptian plasma-phot0043.jpg   I-Channel CNC Egyptian plasma-phot0046.jpg   I-Channel CNC Egyptian plasma-phot0047.jpg   I-Channel CNC Egyptian plasma-phot0062.jpg
    Jun 2009
    Egypt
    Four sides of the base, each two are identical.
    Base legs.
    Attached Thumbnails Attached Thumbnails I-Channel CNC Egyptian plasma-phot0058.jpg   I-Channel CNC Egyptian plasma-phot0059.jpg   I-Channel CNC Egyptian plasma-phot0066.jpg   I-Channel CNC Egyptian plasma-phot0067.jpg
    I-Channel CNC Egyptian plasma-phot0065.jpg   I-Channel CNC Egyptian plasma-phot0069.jpg
    Jun 2009
    Egypt
    I Channel drilling to fix the basment and for legs.
    Attached Thumbnails Attached Thumbnails I-Channel CNC Egyptian plasma-phot0081.jpg   I-Channel CNC Egyptian plasma-phot0082.jpg   I-Channel CNC Egyptian plasma-phot0085.jpg   I-Channel CNC Egyptian plasma-phot0086.jpg
    I-Channel CNC Egyptian plasma-phot0096.jpg   I-Channel CNC Egyptian plasma-phot0094.jpg
    Jun 2009
    Egypt
    Question
    Welding the side bearings support in the laser cut parts.
    Attached Thumbnails Attached Thumbnails I-Channel CNC Egyptian plasma-007.jpg   I-Channel CNC Egyptian plasma-008.jpg   I-Channel CNC Egyptian plasma-001.jpg   I-Channel CNC Egyptian plasma-003.jpg
    Dec 2011
    España
    beautiful, thenks for the pictures ¡¡¡¡
    Jun 2009
    Egypt
    Quote Originally Posted by purper View Post
    Thanks for ur comment Purper, so sorry for the low quality pics.
    Jun 2009
    Egypt
    Some welding processes has been done for the sliding blocks and pre-installed today as illustrated in the attached photos.
    Attached Thumbnails Attached Thumbnails I-Channel CNC Egyptian plasma-img00135-20120209-1159.jpg   I-Channel CNC Egyptian plasma-img00136-20120209-1234.jpg   I-Channel CNC Egyptian plasma-img00137-20120209-1347.jpg   I-Channel CNC Egyptian plasma-img00138-20120209-1347.jpg
    I-Channel CNC Egyptian plasma-img00141-20120209-1553.jpg   I-Channel CNC Egyptian plasma-img00145-20120209-1607.jpg
  • Page 1 of 5 1234 ... LastLast
    1. encoder wiring channel A and channel B
      By senor J. in forum Gecko Drives
      Last Post: 12-13-2011, 10:30 AM
    2. I/O Channel Parameters
      By Probe Guy in forum Fanuc
      Last Post: 11-06-2008, 02:33 AM
    3. What bit to use to drill C channel?
      By teamtexas in forum General Metal Working Machines
      Last Post: 11-03-2007, 12:58 PM
    4. IRC channel for EMC
      By Dan Falck in forum LinuxCNC (formerly EMC2)
      Last Post: 12-18-2004, 12:03 PM
    5. Two steppers from one channel?
      By m1911bldr in forum General Electronics Discussion
      Last Post: 03-29-2004, 09:30 PM
