Thought I would share some of my build pictures so far.
My build is a 4 x 6 Plasma/Router table that will be expandable to a 4 x 8 later when the space is available.
So far I have completed the lower table and upper table. I have designed it so I can unbolt to upper table to make it easier to transport as it will eventually be moving into a bigger shop.
Table:
4x6
V bearings using PCB ivtaag rails for the y axis
V bearing using PCB ivtaaq rails for the x axis
K2cnc for my Z axis
5" watertable
CandCNC 5 axis setup with
Dual Y Drives 2 x 960,
X axis 1 x 740
Z Axis 1 x 620
Rotary Axis 1 x 740
LinkBack URL
About LinkBacks
