Outlet needs to be at the bottom of the tank.
I never fully understood how these work , but I know it has to be simple . I looked and looked for a sketch of the plumbing but never could find one ,so I winged it ! I filled the table with 75 gallons of water and drained it in the tank . I aired up the tank to 10lbs of air and opened the tank water drain valve to fill the tank . It only blows air in the table . I put more water in , thinking the water has to be over the tank inlet and outlet fittings , it still blows air . Should my inlet air pipe be in the bottom of the tank ? I have no piping inside the tank .Please study my plumbing pictures , and a big thanks !!!!
Pipe connecting tank to table should be connected at the bottom of the table (obviously) and also connected at the bottom of the tank.
Pipe for air to tank should be at the top of the tank.
EDIT: With the tank on its side the side nearest the floor is the 'bottom'. Rotate the tank until a side inlet is at the bottom. Maybe you will have to compromise for the air inlet and put it at what would be the top inlet with the tank standing upright unless there are two side inlets opposite each other.
I'm sorry but I still dont understand ? The drain is in the bottom of the table . The tank is on its side . The tank has two identical threaded openings [located half way up from the floor on the tank , note picture ] Thanks for the replys so far , still dont get it though
Drain on the table should be at the bottom. You got that.
The outlet (tank to table) NEEDS to be at the bottom of your tank. Air should be supplied to the tank at a fitting that is above the full level of the tank when filled. Essentially, what you are doing is pressurizing a volume of air above the water level and pushing on the water; pushing it out the bottom of the tank and up to your table. Water is heavier than air, so you need to push DOWN on it to push it out the tank (think gravity), otherwise the air just blows right out and up to your table.
Just realized you've got a bladder tank (from a well water system?)...
Either way, I'm pretty sure you need to orient that baby such that the water outlet is at the bottom, i.e. the tank needs to be mounted vertically. I have never used one of these specifically, but as it is basically the same as a hydraulic accumulator, and that's the general rule. Also, check on the pressure ratings of the unit. At 10 PSI, you may not be fully inflating the bag...
The other odd thing is that you're getting air out at the table... is it constant? You might have a blown bladder...
The wellmate tank does not have a internal bladder , its just plain fiberglass . They make those tanks with or without the internal liner . This one has no liner . I scored it as a freebe ,it was left by the dumpster at Culligan Water . I asked them if I could have it they said they didn't know if it was anygood or not . Turns out its like new a 600.00 tank free !
Cool! Always nice to score a freebie.
Well, either way, since you have only a fitting at top and bottom, you'll have to orient the tank vertically to get the water out. Air in at the top, water out thru the bottom...
Take a look at my machine build http://www.cnczone.com/forums/plasma...ble_build.html
I put a couple of videos on there of my table filling up. The drain, ANDthe water outlet must be on the bottom !! The 10 PSI of air pushed on top of the water to push it out.
On my tank, it looks like the outlet is on top( which it is) but the pipe continues to within 1 inch of the bottom of the tank.
If you need anymore help, PM me and I will make you a small video on how it works.
I looked at your pictures, and that setup will not work. Like stag53 said, you will have to flip the tank vertically, and drill an air fitting on the opposite end of the tank for an air fitting.
Dan
The one that dies with the most tools, WINS !!
www.dantechfabricating.com
Guys would this be an option , since I really want the tank under my table ?
Keeping the tank positioned as shown
1. The fitting where the water drains into the tank at the tank , place a tube or pipe inside the tank to within one inch of the bottom
2. There is a female fitting in the top of the tank I hand already fiberglassed in [you dont see it in the pictures] . Use this fitting to put air in the tank , there by pushing air down on the liquid in the tank , thru the suction pipe inside the tank , which is one inch from the tank bottom
Would this work , and thanks for all the help so far !!!
1. The fitting where the water drains into the tank at the tank , place a tube or pipe inside the tank to within one inch of the bottom....
Yes having a dip tube like this is equivalent to having the outlet at the bottom.
2. There is a female fitting in the top of the tank I hand already fiberglassed in [you dont see it in the pictures] . Use this fitting to put air in the tank...
This will work. Actually it does not matter where you put the air into the tank even if the air inlet is below the water level because the air, of course, bubbles up through the water. However if you want to vent the air out and you have the air inlet below the water level you will get water coming out of the air inlet. To prevent this you need to pump a second internal pipe going up so it ends above the water level.
Thank all of you, I believe I understand now !!!
Merry Christmas
