Results 1 to 7 of 7
Thread: Sheetcam and plasmabot
    Sep 2007
    Hey guys,
    I'm running into kind of a strange issue. First some background info. I am using Autocad to generate my drawings, just simple squares and circles to start out. I am then using SheetCam to convert the dfx files into gcode. From here importing into Mach3. According to tulsaturbo I should be using the MP 100-THC post processor. Everything looks fine in Autocad and sheetcam but the problem is when using this post processor I get some strange gcode generated when there are are arcs present. What happens is sometimes the arcs totally reverse or are much larger than what they should be; say if there is a rounded corner instead of just rounding the corner you get the opposite of that arc generated. See the image below. I believe there is something in this post processor causing this because I tried the Mach3 post processor and the arcs are generated correctly. Anyone have any ideas about what I'm doing wrong here? Thanks!
    Sep 2007
    Fooled around with the post processor code a bit and it seems that the following codes: G53 G90 G40 have something to do with it. I compared this to the standard Mach3 post processor and it has: G40 G90 G91.1 listed. Looked them up but I really dont understand the definitions.
    Registered johndjmix's Avatar
    Dec 2011
    Hakbot, slightly off topic ... I'm building a machine right now so I'm a bit new to this.
    My understanding is you do drawings in autocad, convert to Gcode in sheetcam, then feed into mach3 to run the machine.
    Are you saying mach3 can do the conversion so there is no need for sheetcam? Why not just use that then since your problem isn't happening that way?
    --John
    Aug 2011
    you have to use shhetcam or a similar cam program to create the G-code. mach3 only reads the G-code
    Sep 2007
    Here is my post processor code for the MP 1000-THC, does this match what you guys are using?
    function OnAbout(event)
    ctrl = event:GetTextCtrl()
    ctrl:AppendText("plasma MP1000-THC post processor\n")
    ctrl:AppendText("\n")
    ctrl:AppendText("Modal G-codes and coordinates\n")
    ctrl:AppendText("Comments enclosed with ( and )\n")
    ctrl:AppendText("M03/M05 turn the torch on/off\n")
    ctrl:AppendText("Incremental IJ - set in mach2\n")
    ctrl:AppendText("The torch is referenced at cut start and every 500mm of movement thereafter\n")
    ctrl:AppendText("Designed for use with Mach3 and CandCNC MP1000-THC and Floating head Touch-n-Go\n")
    ctrl:AppendText("Post variables:\n")
    ctrl:AppendText("refdistance - set the distance between each reference\n")
    ctrl:AppendText("switchoffset - set your net switch offset amount \n")
    end
    --post.SetOptions(post.ARC_SEGMENTS)
    -- created 1/1/06
    -- Based on plasma1.post
    function OnInit()
    post.SetCommentChars ("()", "[]") --make sure ( and ) characters do not appear in system text
    post.Text (" (Filename: ", fileName, ")\n")
    post.Text (" (Post processor: ", postName, ")\n")
    post.Text (" (Date: ", date, ")\n")
    if(scale == metric) then
    post.Text (" G21 (Units: Metric)\n") --metric mode
    else
    post.Text (" G20 (Units: Inches)\n") --inch mode
    end
    post.Text (" G53 G90 G40\n F1\n")
    minArcSize = 0.2 --arcs smaller than this are converted to moves
    dist = 9999999
    refdistance = 10* scale
    --Put your switch offset value here
    switchoffset =.052
    lastz = 0
    end
    function OnNewLine()
    post.Text ("N")
    post.Number (lineNumber, "0000")
    lineNumber = lineNumber + 10
    end
    function OnFinish()
    endZ = safeZ
    OnRapid()
    endX = 0
    endY = 0
    OnRapid()
    post.Text (" M05 M30\n")
    end
    function OnRapid()
    dist = dist + math.hypot(endX-currentX , endY-currentY)
    post.ModalText (" G00")
    post.ModalNumber (" X", endX * scale, "0.0000")
    post.ModalNumber (" Y", endY * scale, "0.0000")
    post.ModalNumber (" Z", endZ * scale, "0.0000")
    post.Eol()
    end
    function OnMove()
    post.ModalText (" G01")
    post.ModalNumber (" F", feedRate * scale, "0.0###")
    post.Eol()
    end
    function OnArc()
    if(arcAngle <0) then
    post.ModalText (" G03")
    else
    post.ModalText (" G02")
    end
    post.Text (" I")
    post.Number ((arcCentreX - currentX) * scale, "0.0000")
    post.Text (" J")
    post.Number ((arcCentreY - currentY) * scale, "0.0000")
    post.Eol()
    end
    function OnPenDown()
    if(dist >= (refdistance/scale)) then
    dist = 0
    -- modaltext (" G00")
    -- text(" Z")
    -- number (pierceheight * scale, "0.0000")
    -- eol()
    post.ModalText(" G28.1 Z")
    post.Number(3 * scale, "0.00")
    post.Eol()
    post.ModalText(" G92 Z0.0\n")
    post.Text(" Z")
    post.Number (switchoffset, "0.0000")
    post.Eol()
    post.Text(" Z")
    post.Number (pierceHeight * scale, "0.0000")
    post.Eol()
    else
    post.Text(" Z")
    post.Eol()
    end
    if (preheat > 0) then
    post.Text ("\n G04 P")
    post.Number (preheat,"0.###")
    post.Eol()
    end
    post.Text ("\n M03\n")
    if (pierceDelay > 0) then
    post.Text (" G04 P")
    post.Number (pierceDelay,"0.###")
    post.Eol()
    end
    end
    function OnPenUp()
    post.Text (" M05\n")
    if (endDelay > 0) then
    post.Number (endDelay,"0.###")
    post.Eol()
    end
    end
    function OnNewOperation()
    post.Text (" (Process: ", operationName, ")\n")
    if (plungeRate <= 0) then
    post.Warning("WARNING: Plunge rate is zero")
    end
    if (feedRate <= 0) then
    post.Warning("WARNING: Feed rate is zero")
    end
    end
    function OnToolChange()
    post.Text (" M06 T")
    post.Number (tool, "0")
    post.ModalNumber(" F",feedRate * scale,"0.#")
    post.Text (" (", toolName, ")\n")
    end
    function OnNewPart()
    post.Text(" (Part: ",partName,")\n");
    end
    function OnDrill()
    OnRapid()
    OnPenDown()
    endZ = drillZ
    OnMove()
    OnPenUp()
    endZ = safeZ
    OnRapid()
    end
    Registered tulsaturbo's Avatar
    Feb 2008
    I did a comparison with the MP 1000-THC post file that I use and I don't have the following line:
    My Blog
    http://www.needfulthings.net/tulsaturbo/myblog/index.php
    Sep 2007
    Removing that line didn't seem to help. I am guessing its something with this latest version of sheetcam, went back to a previous version and it was fine.
    1. Johns 4x4 Plasmabot 4.0 Build Thread
      By johndjmix in forum Plasma, EDM and other similar machine Project Log
      Last Post: 04-11-2013, 07:49 PM
    2. My PlasmaBot
      By tulsaturbo in forum Plasma, EDM and other similar machine Project Log
      Last Post: 07-12-2012, 09:16 AM
    3. plasmabot question...
      Last Post: 12-17-2011, 05:02 PM
    4. Plasmabot instructions?
      By HakBot in forum Plasma, EDM and other similar machine Project Log
      Last Post: 12-17-2011, 02:38 PM
    5. Replies: 2
      Last Post: 01-26-2011, 07:15 PM
