Results 1 to 5 of 5
Thread: Adding Plasma to a CNC Router - Hybrid?
    Apr 2011
    I have been doing CNC work for a little over a year now with a small bench top router. I have upgraded to this Wart Hog Router I picked up for $1400. I am adding sme electronics to this to get it to work 100%, but thats a whole other topic.
    My question here is can I make this a hybrid Router/Plasma? My thought as, i could have a removable water table and shims that I throw in the machine when i want to do plasma work. And simply remove it when i want to do wood work. Its a rack and pinion system on the X and Y and a screw for the Z. My rapids that I have been testing are around 400-450 ipm. This seems like it should be fast enough? Thanks guys for your input.
    Oct 2006
    The main difference you will have is the torch. You will want something that handles the TorchFire and the OK to Move signals. Then if you want THC you will need something that monitors voltage and adjusts. Check out CandCNC for his THC if you use Mach. You will also want to build a torch holder that has a floating head with a switch so you always know where the material 0 is.
    I have my machine setup for 3 tools. Plasma, Engraver and a Spindle so its doable.
    Apr 2011
    How about the water table.. it absolutely can not be plastic? and also, why do people use containers under the table to reuse the water?
    Registered johndjmix's Avatar
    Dec 2011
    I'm wondering the same...why reuse the water, water is practically free and it would be easier to just drain the water and bring in fresh.
    --John
    4R8
    4R8 is offline
    Nov 2010
    for smaller machines, it would be easier.
    For a 5x5 and larger it's easier and quicker long term to store below and reuse.
    Filling a table via garden hose takes a long time. Time which could be spent cutting. Filling a table with a well designed bladder system is much quicker.
    The main reason people use a bladder is additives are used to reduce rust and corrosion of the parts and the table itself, reusing mean not re mixing each time the table is used. It also lowers the evaporation rate as no fluid is exposed to air and means the table can be cleaned without remixing more fluid.
    1. Adding a laser to gantry router questions
      By SScnc in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 11-09-2011, 01:06 PM
    2. Adding plasma to a Chinese CNC router
      By epilotdk in forum Chinese Machines
      Last Post: 11-07-2010, 03:25 PM
    3. CNC Router Hybrid Wood/Steel
      By Grandad in forum CNC Wood Router Project Log
      Last Post: 03-25-2009, 08:24 PM
    4. Plans for Joe's Hybrid CNC router?
      By jeffmorris in forum Joes CNC Model 2006
      Last Post: 08-12-2008, 07:05 PM
    5. New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter
      By the__extreme in forum CNC Wood Router Project Log
      Last Post: 02-26-2007, 03:58 PM
