Results 1 to 4 of 4
Thread: New water table
    Aug 2008
    UK
    New water table
    I have an aluminium water table on my plasma table. The steel particles are now starting to corrode thru the alloy surface. I want to build a new one and am thinking it should be made from pre galvanised sheet. Anyone have any views on this? Are there any down sides to this ?
    WSS
    WSS is offline
    Registered WSS's Avatar
    Mar 2009
    U.S.A.
    You are getting a reaction from the two different materials. Go with plain steel and use the plasma quench recipe (sodium nitrite and physan) to stop the rust. I have some pieces in the bottom of our tray that have been there since the water table was installed and they look like the day they were cut, bright and rust free.
    Just one avenue of thought.
    WSS
    www.metaltechus.com
    Aug 2008
    UK
    Quote Originally Posted by WSS
    WSS
    If I make from pre Galvanised sheet will the sodium nitrite react with the Galv ?
    WSS
    WSS is offline
    Mar 2009
    U.S.A.
    Not sure if the sodium nitrite will react with the galvanised, but pretty sure the steel you are cutting will react with the galvanised sheet, again two disimilar metals.
    You could try and mix up a gallon batch kinda strong and put some galv pieces in there. ebay has planty of the stuff in both large and small quantities.
    WSS
    www.metaltechus.com
  1. What do you do with your water table waste water?
    By turboedgs in forum Plasma, EDM and other similar machine Project Log
    Last Post: 07-28-2010, 05:33 PM
  2. Need Help!- Does anybody know what to mix in the water, on a water table?
    By suzukirmz in forum General Waterjet
    Last Post: 06-22-2008, 12:56 AM
  3. DYNA CNC TABLE WITH WATER TABLE
    By DISCONNECTED in forum General Waterjet
    Last Post: 06-06-2008, 09:04 PM
  4. Water Table
    By Big John T in forum General Waterjet
    Last Post: 05-07-2008, 09:32 AM
  5. Water transfer techniques for water table?
    By Knut in forum General Waterjet
    Last Post: 02-02-2007, 10:52 AM
