Results 1 to 5 of 5
Thread: What's the best way to drive the gantry?
    Aug 2008
    I see most machines use a rack and pinion, but I thought about using a cogged timming belt. This way I could mount the drive motors on the plasma table and keep the gantry a little lighter.
    I was recently looking at another build, and I'm now thinking of using a #35 chain and sprockets. What do you think of this approach?
    Chains and sprocket are a lot cheaper than belts and pulleys too.
    Dan
    Welcome to www.dantechfabricating.com
    Registered mike2768's Avatar
    Oct 2008
    Hi there, I'm just finishing a cnc plasma build using #25 chain and sprockets. I must say they are very smooth running. You can check out my machine on youtube do a search for mike2768. I had mine this past weekend running at its max of 2200 ipm and you know even at that speed it runs smooth. Here's a link of a few pictures before i finished it.
    http://www.cnczone.com/forums/plasma...ter_build.html
    Aug 2008
    Very nice Mike !!
    The more research I'm doing, the more I think that chain is the way to go.
    Did you use it on the X axis also?
    BTW, where in Ontario are you located ?
    Dan
    Oct 2008
    Yes i used it on both the X and Y axis. I live about an hour north of Toronto. Where are you located?
    Mike
    Aug 2008
    I live an hour East. Newcastle
    1. Gantry drive
      By Kentuckyfarmer in forum Plasma, EDM and other similar machine Project Log
      Last Post: 01-29-2011, 12:11 AM
    2. Need Help!- Plama Cutter Gantry Drive Unit
      By antsals in forum Plasma, EDM and other similar machine Project Log
      Last Post: 01-08-2011, 09:53 AM
    3. Aluminum gantry and chain drive x
      By gualalasmooth in forum DIY CNC Router Table Machines
      Last Post: 12-20-2010, 12:22 AM
    4. How do you drive your gantry cnc
      By nash in forum Polls
      Last Post: 12-07-2006, 09:54 PM
    5. Dual Drive Gantry Question?
      By Syphontek in forum General Waterjet
      Last Post: 03-13-2006, 12:51 PM
