Page 1 of 3 123 LastLast
Results 1 to 12 of 26
Thread: DIY plasma/router
    Mar 2005
    australia
    DIY plasma/router
    hello every one i love this site. with out this site i would have not even thought about building a cnc machine. i am posting because i am ready to start building my machine i have every thing except electronics and steel witch should be here this week(hopefully) i have some drawings witch i can post if anyone is interested
    Dec 2004
    Surrey BC Canada
    im always interested in other people's design and ideas
    Mar 2005
    australia
    here are some of the drawings that i spoke of as you can see the y+z asises are not complete yet, i am waiting for the motors to turn up so i can finish that part
    Attached Thumbnails Attached Thumbnails DIY plasma/router-cncview1.jpg   DIY plasma/router-cncview2.jpg   DIY plasma/router-cncview3.jpg   DIY plasma/router-cncview4.jpg
    Sep 2005
    Philippines
    Very nice design
    Hi! You do have a very good design.
    I am also planning to buid one; but right now I am thinking of a 6' gantry with electronics complete from Dynatorch. Then I will built the table.
    Seeing your sturdy design, I am thinking if it is wiser to just buy the electronics and built the gantry and the table.
    Btw any user out there of Dynatorch? How does it fare in usage since it is a DC servo closed loop system. In comparison with competitors it seems fewer people are using Dynatorch? Am I right in my assessment? Thanks for comments
    Dec 2004
    Surrey BC Canada
    i like ur idea for the grating part and why did u choose to have the table soo low? and what materials are u planning on cutting (max size) other than that the design looks good and will work.. did you ever find out how much that igus stuff would cost? i havent really contacted them yet but am wondering how expensive they are..
    Mar 2005
    australia
    hi the finished table height will be 700mm to the top of the cutting surface ididn't want to have it any higher then that because it would be to hard to reach the centre of the table. i am planing to cut 1500x3000x12mm sheets of m/s max. the table travel is 1800x3300x220mm i have bought 3 x 6' lengths of igus chain these are the spics- open style side hinge cable and hose carrier 1.38"H x 2.87"w overall sz. 3.94" bend radius they cost me $90US each plus mounting brackets $27US a set. i bought these from mcmaster-carr
    Registered Inventthis's Avatar
    Nov 2004
    Really nice. What motor torque are planning to use to move the gantry?
    Just one motor to drive the gantry?
    Mar 2005
    australia
    hi i am planing to use 2 closed loop servos 600oz-in
    Mar 2005
    australia
    Table frame made! i have casters on the under side of table to allow me to move it around while i work on it
    Attached Thumbnails Attached Thumbnails DIY plasma/router-dscf0473.jpg   DIY plasma/router-dscf0472.jpg
    Dec 2004
    Great Job on the frame. What size frame material are you using?
    Herman
    Disclaimer: Not affiliated with any company or business. Happily Retired.
    Moderator Switcher's Avatar
    Apr 2005
    mydxf.blogspot.com
    terrydullaway,
    Your machine design, Looks very good.
    With your "X-axis" rails on the outside of the machine, It should prevent slag from getting on the rails
    Mar 2005
    australia
    I am using 250X150X5mm RHS for frame, i used this size so that i can span 3600mm with out table flex.
    X axis bearings will also have a shroud covering them to further protect them from slag etc.
  • Page 1 of 3 123 LastLast
