Page 4 of 4 FirstFirst 1234
Results 37 to 39 of 39
Thread: CNC plasma build, or bust.
  1. #37
    Registered arewehavingfun's Avatar
    Jan 2009
    Quote Originally Posted by xavier2nd View Post
    So is this thread still about a DIY plasma table or has it changed?
    Hows the progress going?
    Sorry about that, I really am. This is not fear to the rest of you.
    I have some great information about a rail system that I am building. Super cheap method of maintaining a steady linear motion, without the cost.
    Joe
    Anything is possible, just build it!
  2. #38
    Jan 2009
    Quote Originally Posted by jimcolt View Post
    That is where it started with the original poster.....he has shifted a bit to talking about his choices of plasma for the build (which he has not covered much....just showed a picture of a stepper motor and some bearings and hardware....then posted a pic of a Torchmate machine with another plasma. I'm not sure what exactly is going on with the build....
    Jim
    This is the cr#p I'm talking about. Those stepper motors were attached to carriages I personally designed and made for the build. That Torchmate table had the amazing Everlast pp60c plasma torch I want to buy.
    Who do you think you are Jim Colt?
    They should throw your ars out of here, for the amount of disrespect you show.
  3. #39
    Jan 2008
    So....then how about getting back to the subject of this thread that you started. It is supposed to be about your cnc machine build. Share some details of your personally designed carriages and your machine design. This is the CNC zone.....most readers are here to talk about cnc machines, their operation, their design, and what they are to be used for.
    Lets get back to the subject.
    Here it is, in your words from the first post:
    CNC Plasma, Build or Bust
    The thought process on how I'm going to create a CNC plasma table has been addicting and time consuming to say the least. I am constantly going up and down on my build’s, "wish list". When all is done and said, I come to the same chilling fact that I have to build the CNC with the least amount of resources. However, the best resource I have is free, that's knowledge from folks like you. I welcome any and all opinions, also criticisms to say the least.
    The plan is to have a three-foot by five-foot working CNC plasma table when finished. The main frame will be three inches by three inches square steel tubing. The gantry’s main beam will also be the same, respectfully. The rail system will, no doubt be a four inch width by a hundredth and eight-five thousands thick cold rolled piece of, well, I believe ten-eighteen mild steel at this moment. Carriage for the rails will be complemented by using products from “CNC Parts” company. Of course, this may change too, depending on how conservative I’m being that very day. I’m not trying to avoid the “Z” (zeeeeeee(trying to be funny)) item but, I might have something rolled up my sleeves on that subject, more to come. Electronics powering and driving this table will be 640 ounce steppers and such from Candcnc. Their Digital Torch Height Control II(DTHC II) board is a must for this guy.
    I’m thinking this is a good start for now, more to come.
    Quote Originally Posted by arewehavingfun View Post
  1. Newbie - To build or not to build Router/Plasma Table
    By dfranks in forum General Waterjet
    Last Post: 04-08-2011, 12:16 AM
  2. 5 axis milling of 3D scanned data (bust)
    By aidsch2010 in forum Rhinocam
    Last Post: 02-26-2011, 05:39 AM
