I've heard nothing but good things about the Harbor Freight refrigerated air dryer. I'm waiting until they go on sale again before buying mine though.![]()
Anyone have any suggestions for an air dryer for a plasma. If you have one and are happy with it please let me know. I am trying to get my plasma working properly and it seems the air might be an issue.
Tony
719-942-3926
Carl
I use a Domnick Hunter regenerative dryer and a motorguard filter as a pre-filter. The DH uses activated alumina as a dessicant and I can run for several months without changing if I change the pre-filter cartridge on a regular basis (once a month). I use the air system several hours per day and have zero moisture in the in any of the bowls. I use this for painting and the plasma cutter and my air tools (grinders, etc).
This dryer system fronts two 60 gal - 3 cyl compressors so I don't generate a lot of water like a single system running all the time
I bought the DH used on Ebay for $125.00 and it's been well worth it.
Willy
