This TS-1000 looks like a great solution for the problems we are seeing in the future.. Also what if there is some kind of chemical you can add into the resin while it is in the mixing stage (liquid) so that it is permanetly imbedded into the glass and resin to help stop the uv light and chemical repelants.. Many things are added to resin in boat construction can we add something along these lines that would not alter the kick off and not be harmful..??
Here is a link that I found to use UV cure/resin instead of two part epoxy.. This would reject all UV light because it is cured by uv but would also act as an epoxy. Im not sure if this is the correct stuff to use just some R&D to help our conversation.
http://www.artclayworld.com/Tips-Tec...structions.pdf
Also what if we dont use anything but fiberglass and resin. Lets let it take its natural course and deteriate over time how long would this take.... Boats last a very long time under harsh environments so my guess a plasma table fiberglass waterbed would have to at least last 3 years... So what build a new one after 3 years, I could make a fiberglass table in probably 12 hours ready to go... Or we could make a plug out of marine ply spray some mold release inside lay the glass resin inside pop it out when hard... Then you would have a mold for your next one however long it would last... What do you guys think about that....
