hey guys... just planning my machine and have 2 sticking points before its all go.. should get going this week!!
1. can you trigger the plasma cutter from the hand piece allowing its removal for use as a normal cutter? or do you have to install a relay circuit.
2. will 425 Oz-in motors be sufficient for a plasma and light routing?
thanks guys just need these two points clearing up
LinkBack URL
About LinkBacks
