Results 1 to 3 of 3
Thread: water table question
    HMD
    HMD is offline
    Jul 2007
    I would like to know how far down on my plasma water table the distance between the top of my slats and the top of the table. I have seen some at 3 or 4". I wil be loading 10 ga to 1/4" steel by hand. I just dont want water on the floor. The water tray is 8" deep with air chamber underneath. I wish I could keep the slats flush with the top of the table for easier loading. Feedback please,thanks.
    Nov 2011
    Poland
    Your post is from a while back, but perhaps your still around. I just tested out my first water table today, and I have less than 2" from the stop of the slates to the top of the table. I'm afraid that I will get some splashing once I get the table going. What distance did you end up setting up and have you experienced splashing.
    Jun 2009
    Netherlands
    Here is what I did.
    My watertable is 5 inches deep, the slats are 2 inches and level with one end of the table (photo). I can just slide the sheets on from this side. One the other 3 sides I attached a sheetmetal "angle iron" which reflect the sparks and splatter back into the table. I also made the watertable 10 feet long out of 12 feet cutting length, for easier access. In the rare occasion I cut any longer than 10 feet I just let the torch run over the edge of the watertable. I had the same setup on my previous build and it works fine for me.
  1. Water table size question
    By microdot in forum Plasma, EDM and other similar machine Project Log
    Last Post: 02-11-2010, 11:33 AM
  2. Water Table Question !
    By Pure-Powder in forum General Waterjet
    Last Post: 04-23-2008, 02:15 PM
  3. Water table question
    By DRL in forum General Waterjet
    Last Post: 03-28-2008, 12:23 AM
  4. Water Table Question !
    Last Post: 03-06-2008, 09:09 PM
  5. Water Table Question
    By DISCONNECTED in forum General Waterjet
    Last Post: 11-03-2007, 01:58 PM
