What are the different methods to cut the torch off when hitting the e-stop?
Right now I still have an active (on) torch when I hit the e-stop and I have to manually turn that off as well. As you can imagine this isnt ideal.
Is there a way to write a torch (off) command (in my case and m5) into the e-stop command in mach?
I’m just fishing for options.
