Results 1 to 2 of 2
Thread: Problem with THC 301D
    Apr 2007
    india
    This is the first time i am starting to cut on 8 mm Mild Steel. I have peculiar problem. My torch pierces and when it starts to cut it goes up from intial cut height of 1.6 mm to 9 mm ,which is the upper limit i have set and then stops and the final arc volts reads 190 upwards. This is the first time i have encountered such a problem.
    My Settings for 8 mm Mild Steel are
    Arc voltage 139
    Pierce rate 25 IPM
    cutting speed 75 IPM
    Please help.
    Mar 2010
    china
    check yr upper limit switch if it has problem, it might keep sending up signal.
    and check the dross of torch,
    the strange thing is plasma reads 190, torch should dive on voltage spike, if your THC has no auto mode freeze function.
    But your torch keeps going up.
    larry
    stand alone torch height controller supplier
    http://www.hydcnc.com/en/
  1. HELP! THC 301d not responding, any ideas?
    By Wolfesmetalfab in forum General CNC Plasma And Oxy Fuel Cutting Machines
    Last Post: 02-15-2013, 03:46 PM
  2. Replies: 5
    Last Post: 08-04-2010, 06:33 PM
  3. machine problem or software problem?
    By bcnc in forum Syil Products
    Last Post: 10-26-2009, 10:51 AM
