Results 1 to 9 of 9
Thread: Stepper Questions 23 vs 34
    BBR
    BBR is offline
    Jun 2003
    Think about ordering this kit.
    NoSleep Studio
    Was curious about the Pro and Cons of Nema 23 vs 34 mounts?
    Any thoughts?
    thanks
    Matt
    Dec 2005
    This is what I have found but don't take it as gospel because there are a lot more versed people than me.
    Nema 23:
    cheaper
    Typically found in lower end cnc kits
    lots available as surplus
    Nema 34:
    larger package footprint
    more available torque
    more expensive
    The only concern that I would have with that kit is the resolution. A lot of people run gear reduction to help the motors out and to gain more resolution. I am going to run 3:1 on my new table and my old one ran 10rev/inch.
    BBR
    BBR is offline
    Jun 2003
    I figured the resolution can easily be fixed with a belt drive reduction set up. Looking at the drive plates it should be pretty easy to adapt the reduction drive to it or once it's up and running I would be able to cut new drive plates to convert it.
    I was looking at the ease of this kit with all parts being cut and ready to mount.
    These plates have mounting for 23 but I would prefer the 34 to go with the CandCNC kit I will be purchasing.
    Dec 2005
    My setup does run the belt reduction and Nema 23 motors. To be honest it would be cool to have bigger motors, but I don't need them. Atleast I haven't talked myself into how much I absolutly have to have bigger motors.
    That kit does look really clean. Not a lot of extra stuff and the assembly looks well thought out.
    How big of a table are you going to make? What type of cutter? What type of parts and metal are you going to be cutting?
    All of this is what I should have taken into account when buying my drive setup. Instead I bought the cheapest setup I could find that people didn't give bad reviews of. The size 23 motors have plenty of torque for non-contact material removal when used on smaller machines.
    Oct 2008
    BBR, I have the bladerunner setup, and think I will like it. I have seen the no- sleep first hand and believe I could have done 90% of what I need to do with it....but I just overbuild everything..........jb
    BBR
    BBR is offline
    Jun 2003
    Im going to start building a 4 x 6 table with one of the Candcnc Plazpak kits. I plan on using the Nema 34 Steppers so I hope they can make the drive plates with the 34 mounting holes.
    My base frame is going to 3" square stock with the gantry assembly mounted on top using 2"x3" aluminum railing.
    The gantry kit seems pretty well thought out and would work well in a heavy duty build. For the most part its the frame that supplies the rigidity for the machine. The V rail set up is nice and has been used on many large scale machines.
    This will be used for a multi-process machine- plasma, routing of aluminum faceplates for enclosures and maybe some engraving.
    -Boogiemanz1
    "I could have done 90% of what I need to do with it....but I just overbuild everything"
    Wondering what your building? What part of this gantry wouldn't hold up to your expectations?
    Oct 2008
    BBR, I want the ability to put a 4x8 sheet of 1/2" steel on my machine. If you keep your gantry around 80lbs, the 620 oz 23 steppers should do fine for plasma since the tool (torch) has no drag on the work. Routing would depend on how much you were cutting. I only plan to use my machine for plasma and am building it fairly heavy just to support the material.....jb
    Jan 2011
    I just bought a kit from NoSleepStudio..... Just got it in the mail and looks nice... Will be doing a write up on it maybe starting tonight... I'm doing a 4x4' build... I think it is going to be money well spent on his kit... Takes all the guess work out of building this thing!!!... Photo is sort of a sneek peek..lol
    Attached Thumbnails Attached Thumbnails Stepper Questions 23 vs 34-img_0085.jpg
    Oct 2008
    I went to his shop one afternoon and would have bought one from him if I had not already invested about 6K in my setup. I am still a month out on mine, and I probably could have been cutting parts a couple of months ago if I had gone with his.......jb
    1. New Machine Build- Stepper Driver Questions
      By niwatori1 in forum Open Source CNC Machine Designs
      Last Post: 11-26-2009, 09:46 PM
    2. Stepper Driver Questions
      By bcromwell in forum General Electronics Discussion
      Last Post: 09-25-2006, 04:01 AM
    3. A few stepper questions...
      By snooper in forum Stepper Motors and Drives
      Last Post: 07-18-2006, 02:03 AM
    4. Stepper Motor Questions
      By spuds in forum Benchtop Machines
      Last Post: 05-25-2006, 02:34 AM
    5. Random stepper questions
      By chuckknigh in forum DIY CNC Router Table Machines
      Last Post: 11-08-2003, 11:45 AM
