Results 1 to 3 of 3
Thread: CNC inline Oxy/plasma Cutter
    Jan 2006
    Hello all. I am in the planning stages for a retrofit of a inline track cutter. We use this at my place of employment for chamfering the cutting edge for Heavy Equipment buckets (loaders, excavators ect.)
    We use a motorized inline track to move the oxy fuel torch. The edges are clamped into a hydraulic clamping table.( more info and pictures to come later)
    I want to use cnc to control this machine, x y and z. My first question, I was planning to use Mach3 software with a mpg2 pendant. I want it to travel X down the edge, with the ability to override Y with the pendant and make adjustments ( to compensate for warped material) while travelling. I would think this is possible?
    I have made a general proposal for the cnc retrofit of this machine to my employer and now just looking to iron out the finer details.
    Oct 2008
    You may want to use a torch height control if you are going cnc. Tom at CandCNC.com , or some of the vendors on this forum could probably have a solution for you..........jb
    Jan 2006
    Thanks for the reply, I do plan to have THC on Z axis for cutting plasma. it's the Y axis, (left and right) while travelling X down the table I need to be able to adjust on the fly. My oxy fuel torch will be set at at 23 degree angle, and cutting on the 1-3/4 thick side of a 10" x 118" part. Its standin on its side. Torch travels about 12 ipm. Its Hardox 400 450...
    Could I press the enable button on the pendant and set to Y, and make adjustments (minor) with the handwheel on the pendant? While travelling X?
  1. CNC Laser cutter versus CNC Plasma cutter?
    By squale in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 01-12-2013, 10:57 PM
  2. Plasma Cutter
    By mikie in forum General Waterjet
    Last Post: 03-22-2011, 07:56 AM
  3. Forum Bug- Change in inline images
    By port_huon in forum Forum Questions or Problems
    Last Post: 10-17-2010, 02:08 AM
  4. Lars Martin inline 4 banger
    By woodythx13 in forum I.C. Engines
    Last Post: 08-25-2009, 02:08 AM
  5. Plasma Cutter
    By studysession in forum General Waterjet
    Last Post: 09-03-2007, 10:23 AM
