Page 1 of 2 12 LastLast
Results 1 to 12 of 16
Thread: Torch touch off / floating torch
    Nov 2010
    uk
    Let me just throw this out there for consideration or comment. From what i can see the router and milling boys boys use an electrical contact to get a material hight where us plasma boys it is generally accepted that a floating torch is used. My question is that surely adding an electrical contact to the shroud of the plasma torch this method could be used to acheive the same when plasma cutting ?
    Just a thought, would save a lot of work on a floating head...
    Registered Teknition's Avatar
    Dec 2005
    Yes, it can and is done. commonly referd to as "touch n go", "touch and go", or ohmic contact. Touch and go works with a microswitch in conjunction with a floating head on the Z axis. I beleive ohmic contact would utilize a resistance value between the torch shield and the workpiece.
    Brad
    Nov 2010
    uk
    Ahhh, my next question is going to be, is there any pro and cons to either method ?
    Registered CPierce18's Avatar
    Apr 2007
    I'd like to add a question to that if I may. If I were to hookup a wire to my plasma torch shielding cup, and one to my material grounding wire, so when the machine's torch moves down to find the surface before the cut it completes the circuit and zero's out… If I were to do that, would I fry my breakout board when my plasma fires? I'm confused with that, and i ReAlLy don't want to try it and chance it.
    C. Pierce
    Nov 2010
    uk
    Good question. A simple test with a meter will tell you if you are getting any voltage at the shield when the arc is on. I would suspect your shield is ceramic though ? so you shouldnt. I enviseged using simple probe attached to the torch or similar. Just a thought.....
    Dec 2005
    Quote Originally Posted by Ubatoid View Post
    Im no expert at it by any means, but from what I've gathered, when using the ohmic method, the sheet has to be very clean or it doesnt work well. So if you are cutting steel that is rusty, ohmic would be a second choice unless you really enjoy grinding each sheet before cutting.
    As far as I can see, the only real issue to touch n go would be if you were cutting very thin sheets. When using touch n go, the torch comes down and touches the sheet, causing the torch slide plate to be lifted and therefore closing the microswitch. You can counter load the slide plate with spring/s to take care of some of the torch weight but there must always be some weight present to cause the torch to fall and open the switch. So, if you are cutting very thin sheet, you could run into problems with the sheet bending a bit when the torch travels down.
    As for the wiring question, I will have to refer that one to someone else. From what I have read, the table itself may be in excess of 100 volts when the plasma is running. That is why a proper earth ground rod should be used on the table. My gut feeling is that wont work, otherwise no one would be going thru the trouble of a slide plate and micro switch .Maybe Tom from CandCNC will stop by and answer this one.
    Brad
    Nov 2010
    uk
    You raise a good point there. Whilst the bulk of the thinner sheet we use is spotless, the thicker material does tend to be scaley / rusty. Debate closed I think.
    Thanks for the input.
    Mar 2010
    us
    I would like to add another question
    I notice on youtube plasma videos, many people tend to touch off on the begining of all cuts and some don't. Advantages? and are they adding these extra moves into the code for each reference? Thanks in advance.
    Jan 2008
    OK.....I'll clarify a few things!
    Ohmic contact, or the use of electrical contact between the front of the plasma torch and the plate....to accurately locate the surface of the plate has been used on almost all industrial plasma systems since about 1986.
    Most industrial height controls have a two phase IHS (initial height sensing) system that at the beginning of every cut cycle indexes the torch towards the plate until the shield (or on some older technology torches, the nozzle aka tip) contacts the plate, (sensed electrically) then the torch retracts to the recommended pierce height and fires. If the plate is not sensed electrically due to a painted, masked, or other non conductive surface, then a backup IHS using torque sensing (an increase in z axis motor torque is sensed when contact with the plate occurs) occurs.
    Torque sensing works well on plate that does not deflect, ohmic sensing works well on plate that does deflect (thin plate) as it will sense the surface without any moving.
    I will attach a picture of a Hyperthem Powermax45 torch with the ohmic retaing cap and shield, and a wire attached to complete the circuit.
    So, Ohmic sensing is the most accurate method of finding the surface of the plate, assuming the surface is electrically conductive.
    It should be relatively easy to make the ohmic process work on a z axis height control, as long as you have the correct torch with the ohmic capability. On entry level cnc machines (low cost) I know of at least two that use the ohmic IHS system on their torch height controls, they are PlasmaCam and Dynatorch.
    Jim Colt Hyperthem
    Attached Thumbnails Attached Thumbnails Torch touch off / floating torch-img_2358.jpg   Torch touch off / floating torch-img_2360.jpg
    Aug 2007
    England
    Hi Jim - just to echo CPierce18 above: A thing I've yet to figure out is what is the voltage between the shield/nozzle/tip that your wire is attached to and the table/work when your CUTTING? i.e. is it torch volts?
    Ian
    Jan 2008
    During cutting....the shield and the nozzle are floating....in other words there are no hardwired connections to either. However, if you connected either to an oscilloscope....you would see all kinds of wild voltages during cutting as the arc and the plate is very close to each of these, and there will be transient voltages present. The nozzle in a plasma torch is at the same potential as the plate during the pilot arc only.....as soon as the arc transfers to the plate the plasma system electronically disconnects the nozzle from the positive side of the circuit (older plasma systems actually used a relay called the pilot arc relay).
    The height control system, when it uses the shield to sense contact with the plate to locate the surface....does this before the arc fires, then the connection is usually (depending on the height control manufacturer) disconnected via a high voltage relay while the torch is running.
    Some height controls do monitor the shield while the torch is cutting to detect collisions with the plate....and they retract to the proper physical cut height when a collision occurs (Hypertherm industrial height controls have this ability).
    Hopefully that answers your question.
    Jim Colt
    Aug 2007
    England
    Quote Originally Posted by jimcolt View Post
    Certainly does Jim
    Ian
  • Page 1 of 2 12 LastLast
    1. Floating torch design idea
      By panozeng in forum General Waterjet
      Last Post: 12-20-2010, 03:05 PM
    2. Hypertherm torch touch
      By mathx in forum Hypertherm Plasma
      Last Post: 08-10-2010, 01:07 PM
    3. Hand torch to machine torch
      By matttargett4 in forum Hypertherm Plasma
      Last Post: 06-01-2010, 04:37 PM
    4. hypertherm 1000 hand torch to machine torch
      By duraflap in forum Hypertherm Plasma
      Last Post: 05-18-2010, 03:34 PM
    5. Need Help!- Different between hand torch& machine torch
      By ltran2000 in forum General Waterjet
      Last Post: 03-02-2008, 10:19 AM
