Results 1 to 2 of 2
Thread: Cut Quality THC Please help!
    Jun 2009
    Hello
    Everything is operating what I thought was great, I have been cutting only thin aluminum. Yesterday I was trying to cut 3/8" steel plate. I am using the basic Hypertherm PM45 w/ machine Torch manual recommendations, for pierce height & feedrate etc. I practiced my cut by making a simple 1.25" circles, after I got the test looking good I moved onto my more elaborate part. I was unsuccessful in getting even a single piece cut out 100% complete. One piece got to the last 6" of completion, kept running BUT the torch stopped cutting all the way through the plate.
    I have noticed:
    the torch diving into the metal
    a molten like weld (not cutting all the way through)
    splatter on the shield of the torch
    The attached pic is a basic example of what a couple of the cuts looked like.
    I am hoping someone can help me by looking at my Mach3 Cut Profile settings (these were inputted when I was initially setting up so there could be some major errors) Is there anyone using a PowerMax 45 with Machine Torch that would share your successful profiles/help me in setting up my Cut Profiles in Mach3?
    Tip Volt Preset 120
    THC Delay 1
    Tip Saver % 2 What is a good starting point?
    Arc OK Current 100 What is a good starting point?
    Cut Current 45
    Span Gap 4
    Upper Fault Limit 200
    Lower Fault Limit 50
    Current Tolerance % 100 What is a good starting point?
    I will be starting the next cutting attempts with a new nozzle and electrode.
    Thanks in advance for any and all info
    Eric
    Attached Thumbnails Attached Thumbnails Cut Quality THC Please help!-download-1.jpg
    Mar 2010
    china
    you're using THC, still torch diving happened?
    the workpiece warps, and the cutting speed is too fast for THC, I think.
    stand alone torch height controller supplier
    http://www.hydcnc.com/en/
  1. DIY with quality components
    By yohudi in forum DIY CNC Router Table Machines
    Last Post: 01-26-2008, 04:44 PM
  2. cut quality
    By xjdubber in forum General Waterjet
    Last Post: 10-14-2007, 04:22 PM
  3. cut quality
    By bearwolfe in forum Torchmate
    Last Post: 07-02-2007, 11:06 AM
  4. Is this the quality?
    By Chunky in forum DIY CNC Router Table Machines
    Last Post: 05-30-2005, 11:02 AM
  5. Plasma cut quality
    By Apples in forum General CNC Plasma And Oxy Fuel Cutting Machines
    Last Post: 04-13-2004, 10:18 AM
