Results 1 to 3 of 3
Thread: Using steel for the water table?
    Sep 2009
    Well after a bit of research it looks like I am going with a water table design (at least for now). I have been looking at water table designs from others past projects and see that some individuals have constructed it out of aluminum and others have built the tray using steel.
    I have zero experience welding aluminum and don’t know if I want to learn on this project as mistakes can be costly and time consuming. However I have plenty of knowledge and time with the MIG welding steel. Based on my budget, experience and timeline I am leaning toward constructing the water table tray and related components using steel and then coating them with something? I am looking for suggestions regarding water table construction using steel as the water tray. Any tips or recommendations are very much needed.
    Nov 2007
    Use steel and there is no need to coat it with anything really if you use a rust preventative in the water. I have homemade Plasma Quench in mine, uncoated steel and there is NO rust anywhere.
    Registered Karl_T's Avatar
    Mar 2004
    Dassel,MN,USA
    I went with a mcmaster carr coating, expoxy paint for severe environment. I did inside and out. IIRC, something about coal tar. The machine looks great and no rust at all. Cost was like $70 for a gallon. I brush painted it. I do remember thinning it quite a bit as its thick like tar in the can.
    Karl
    P.S. part number 7953T12
  1. What do you do with your water table waste water?
    By turboedgs in forum Plasma, EDM and other similar machine Project Log
    Last Post: 07-28-2010, 05:33 PM
  2. Newbie- AMAZING - Water on steel, really?
    By jewells in forum General Metalwork Discussion
    Last Post: 09-11-2009, 12:43 AM
  3. water table and support steel weight?
    By Crayola in forum General Waterjet
    Last Post: 02-10-2007, 11:51 AM
  4. Water transfer techniques for water table?
    By Knut in forum General Waterjet
    Last Post: 02-02-2007, 10:52 AM
