Page 1 of 2 12 LastLast
Results 1 to 12 of 16
Thread: K2 Z Axis
    Jun 2009
    Question K2 Z Axis
    Hi all,
    I'm putting together parts to retrofit an old Piecemaker 6.5x13' plasma table. It needs a z axis (currently only has a torch lifter) and I'm considering something like the K2 unit.
    http://www.k2cnc.com/shop/products.asp?cat=33
    I can't see how the floating part moves; anybody have experience with one of these? Is there any slop in the mechanism?
    Thanks,
    Chester.
    Dec 2004
    Surrey BC Canada
    there is total of 4 bearings (one for z axis travel that goes up and down... and other is for the home switch (z touch)
    hope that concept is clear..
    Jun 2009
    Thanks Dan that is a bit more clear.
    Does anybody have any feedback on the K2 units? Is there a better z axis out there at a similar price point?
    Thanks a bunch.
    Chester.
    Dec 2004
    Surrey BC Canada
    np chester.. I never purchased from them or seen them myself.. I dont know other pre fab z axis for sale too..
    Nov 2007
    I bought the 6" version for my table. I have it mounted, but have yet to try it out. For the price, i'm not sure it can be beat.
    I like how compact everything is, and how they've worked in the floating aspect
    only question i have, which maybe someone can answer? Is there typically a home switch for Z up? The only switch that is on the unit is for the floating head.
    during the home process of the table, i'd want the Z to move up first, but how will it know when to stop?
    Jun 2009
    Hi Multi,
    Thanks for the info. I also wonder about a home switch on the z axis for full up travel.
    Any more reviews on the k2 or other z axis'?
    Thanks again all.
    Chester.
    Nov 2007
    Home Z axis switch?
    Multiplex I don't have a home on my Z axis and don't recall having seen one on any other builds either. The only switch on my Z is for my floating head.
    chestrockwell if I needed another Z for another table or to replace the one on my current machine I would buy a K2 - I like the looks of them a LOT.
    Oct 2008
    I think Dnelso's build used a K2 and if I remember there may be a video..............jb
    Nov 2007
    you can see the Z axis a little bit in my video - first test runs of my machine. no torch attached yet
    [nomedia="http://www.youtube.com/watch?v=KwZ0RKWZM_I"]YouTube- CNC Plasma first test[/nomedia]
    Jul 2005
    Quote Originally Posted by multiplex View Post
    The Touch-off switch on the Z is the Z home. Homing up in the air some distance has no meaning. You use homes on a CNC machine to establish a known position from which to measure your cuts. The Z home is normally at Z zero and Z zero is the top of the material (not some place up in the air). Since that changes (especially in plasma cutting) you have to re-establish Z zero.
    I have seen users mount the HOME up on the Z but then you have to either do a bunch of complex math the find the top of the material or reset the Z zero. It won't work with the Floating Torch Holder and the auto touch off for IHS.
    Homing is normally used to reference your table. It establishes a Table Zero. Your part may be offset from there but it allows you to always return to the same place. In most cutting operations the Z is measured from the top of the material , either above it (in plasma cutting) or below it (negative numbers) in routing and milling. In routing and milling everything is nice and flat and the material does not flex and warp and change it's height.
    I have a custom button that is a REF XY (homes just the X and Y and zeros them). You can jog the Z down close to the material, hit the Z zero and then after the initial move and the first touch-off (IHS) you have a true Z home (0) after the switch offset is applied. If you are using SheetCAM and the proper POST all of that is handled automatically.
    The Touch-off move is the homing move and uses homing code to perform. If you try to add another Home switch on the axis it won't work.
    Just be mindful if where your Z is and do not do a "Home All" move. A REF ALL is not to be used in plasma cutting! (unless you want to watch your torch slam down and get dragged across the material (or worse the table grid).
    TOM caudle
    www.CandCNC.com
    Nov 2007
    Awesome explanation Tom, and awesome hardware as well. I'm loving the bladerunner so far.
    My biggest fear was zeroing the z, and breaking things while the x and y clear. Obviously the method of operation is differnt than my router and something I'll have to get used to.
    Jul 2005
    The Z is self zeroing as long as it the Z DRO is somewhat close to the actual position. Once you establish a starting Z zero (even if it's just jogging down untilit touches and hitting the Z zero button then jogging it up) then the machine will keep track of where Z is all the time...even after countless UP and DOWN moves. One advantage of having the Control Software (MACH) move the Z even under THC control is it keeps track of where Z is.
    If you follow some simple rules you will never have to worry about damaging your torch.
    1. Never do any Reference (Home) without material on the table (or the grid covered with a flat sheet of something).
    2. On the first Ref of the day (when you first turn on the machine) Ref each axis separately so you have total control of the moves. Manually Zero each axis after it homes. If you park the gantry at a known spot (0,0 or some distance from it) and manually enter the spot in the XY DRO's THEN do a REF to get dead on; it's a 2 minute drill.
    3. Have your torch move up to a higher spot at the end of a job (you can define a XYZ Ending location in the POST) or use a higher Rapid Clearance value in SheetCAM. To save time I usually run at 1/2" rapid clearance but that can leave you open for crashes from tip-ups. It depends if you are going to monitor the cutting (and have your handy magnet close by) if you want to walk away. I would use higher clearances for un-attended cutting.
    4. In 7 years of cutting I have had a few head crashes but have never damaged my torch. The floating torch holder can be your friend as it will save the torch as long as it can ride up over the obstruction.
    5. You can set the Z home as a limit in MACH. That makes it so if the switch is tripped on anything but a REF (home) move it shuts off motion (E-stop). Just make the Z++ the same pin number as the Z home and you are good to go. The down side is that, depending on the way Z is setup, the homing move may not back off the Z home switch far enough to disengage. If that happens the system will instantly shut down (sees a limit as soon as the homing move is over) and you will have to manually back off the switch. A ramp approach to the switch that has to be at the peak before it triggers will make it easier so the back off distance disengages the switch. That distance is NOT programmable in MACH so you have to try and deal with it mechanically. The other way is to have another switch above the Z home (if you have a design that allows travel past the home switch) and set THAT up as a limit. If you are really paranoid you can mount another limit at the top of Z to prevent moving it too far up.
    6. If you have to create a checklist of things on your table (like every good pilot uses no matter how long they have been flying) and hang it at the monitor. Startup and shutdown checklists.
    7. Program and use the Load Material option we have in the MACH setup and screens. You can preset a location in XY and Z that you can hit the Load Material button and the gantry and torch will move out of harms way, so busting your torch loading a big sheet of material won't happen.
    Cutting with plasma is a different critter than routing. Things happen a lot faster and at there is less reaction time. Keep your head in the game to prevent costly mistakes!
    TOM caudle
    www.CandCNC.com
  • Page 1 of 2 12 LastLast
    1. the Difference of 2-Axis and 3-Axis of Vertical Mill Machine
      By begacon in forum Knee Vertical Mills
      Last Post: 07-30-2009, 07:31 AM
    2. Compare Catia and MCX2 for multi axis lathe/4 axis mill
      By bob1112 in forum General CAM Discussion
      Last Post: 10-10-2008, 08:15 PM
    3. How can I coupling a stepper motor axis directly to other axis?
      By meknik2001 in forum Stepper Motors and Drives
      Last Post: 05-08-2008, 02:54 PM
    4. One axis (z-axis?) computer controlled testing device
      By TsThorsell in forum Stepper Motors and Drives
      Last Post: 02-07-2008, 01:38 PM
    5. New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter
      By the__extreme in forum CNC Wood Router Project Log
      Last Post: 02-26-2007, 03:58 PM
