Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Plasma and Waterjet Machines > Plasma, EDM and other similar machine Project Log
Plasma, EDM and other similar machine Project Log Post your building log of your machine here for all to discuss.
Old 09-19-2008, 04:59 PM
nate is on a distinguished road
Milling machine serving double duty as Plasma Cutter
This will do till i can build a full size plasma table...
ID:	66645   Click image for larger version
ID:	66646   Click image for larger version
ID:	66647   Click image for larger version
Nate.
Ann Arbor Meechigan
Old 09-19-2008, 05:16 PM
Weldtutor's Avatar
Weldtutor is on a distinguished road
Reminds me of the "Ghetto Plasma" thread here in the ZONE a couple years ago.
Very ingenious use of a milling machine in Meechigan Nate!
Problem- T SLOT MILLING CUTTER PACKAGE 5 (ON WALTER CNC CUTTER GRINDER) dharschman Toolgrinding & Toolgrinding Machines 3 09-13-2010 01:25 PM
Install a laser cutter in a plasma machine?????? hoyospetrola Laser Engraving & Cutting Machines 10 11-29-2007 11:51 AM
Use TIG machine as plasma cutter? arsenix Welding, Brazing, Soldering, Sealing 6 11-08-2007 08:59 PM
plasma cutter with 100 percent duty cycle DanOSB CNC Plasma and Waterjet Machines 3 03-20-2006 07:57 PM
Height Control For Plasma Cutter CNC Machine EidenC General Electronics Discussion 3 03-05-2006 06:37 PM
