Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Plasma and Waterjet Machines > Plasma, EDM and other similar machine Project Log
Plasma, EDM and other similar machine Project Log Post your building log of your machine here for all to discuss.
Old 05-04-2008, 02:56 AM
cristian gabor is on a distinguished road
Lightbulb plasma table with mobile water bed
hi evryone
i plan building a plasma table for cutting 6 to 12 mm thik and 1.75/2.2 m steel plates.
the mobile water bed table should help me loading and unloading the heavy plates whitout the risc of ruining my cnc table by :
1. slide the water table from underneath the plasma table
2. load the plate on the water bed (no risc of knocking the expensive machine)
3. push the water bed back underneath the plasma.
4. do the job
beside this ,having that spare room i can fit an removable rotary axis to mill some foam or wood.
i have purcesed the 20 amp 3 axis kit "logitrol" from www.lowcostcncretrofits.com ,
and made the frame of 100/100 "V" profile 2.5 / 3.0 ml
i have ordered drive belts/pinions for X axis , slideway with belt incorporated from isel for y axis and ballscrew 400 mm module from isel as well
no plans for this project just building it and planing as it goes
ANY CORECTIONS ARE WELCOME
I HAVE NO EXPERIENCE ON CNC BUT THE STUFF I HAVE LEARNED FROM THIS WEBSITE ALONG 3 YEARS OF READING
Old 05-04-2008, 09:08 AM
Pure-Powder is on a distinguished road
Post a few pics as you go along, good Luck!
Old 05-04-2008, 09:45 AM
kevin swan is on a distinguished road
Nice idea if you have the space. good luck
Old 05-04-2008, 10:38 AM
Question
some pics in today
what plasma system should i go for?
did any one used "telwin" ?
Old 05-04-2008, 01:06 PM
pics with my work up to this time
ID:	58978   Click image for larger version
ID:	58979   Click image for larger version
ID:	58980   Click image for larger version
Old 05-06-2008, 02:58 PM
Big John T is on a distinguished road
Hypertherm.
John
Old 05-09-2008, 11:24 PM
BlueFin is on a distinguished road
Hypertherm.
BlueFin CNC LLC
Southern Oregon
Old 05-11-2008, 01:45 AM
hi again
i made some more work as you can see in the pics
got the gantry on and sliding wiht ease but if i hold one side fermly i can push the other side about 5 mm max . is this ok or is an major problem ?
(i want to use only one side belt drive )
i'm expecting the z axis on monday and the guide way for y on wensday or so
I got a price for powermax 1650 hypertherm at 9800 $. that is the best price i found
DOES ANY ONE KNOW WHERE CAN I FIND THIS SYSTEM FOR LESS MONEY ?
it sems to my that for 10 mm steel plate i need 100 A plasma to cut at
60A/100% duty cycle
ID:	59388   Click image for larger version
ID:	59389   Click image for larger version
ID:	59390   Click image for larger version
Old 05-11-2008, 10:38 AM
Originally Posted by cristian gabor View Post
hi again
got the gantry on and sliding wiht ease but in i hold one side fermly i can push the other side about 5 mm max . is this ok or is an major problem ?
I guessing you will see some flex during direction changes. It just depends on your product if that is ok or not. It would be simple enough to add a shaft to drive the opposite side...
John
Old 05-12-2008, 02:01 AM
Bigtoy302 is on a distinguished road
hi again
60A/100% duty cycle
List price on that machine is only $4795. Shipping could get tricky though, but not $9800. Check Ebay.
  #11   Ban this user!
Old 05-13-2008, 08:59 AM
hypertherm
  #12   Ban this user!
Old 05-14-2008, 01:14 AM
millman52's Avatar
millman52 is on a distinguished road
I agree with John T. I'd add a jack shaft possibly through the center of your gantry tube. That way 1 stepper will drive both sides equally.
If it works.....Don't fix it!
Plasma+water table on casters? DeviousMW CNC Plasma and Waterjet Machines 1 05-05-2007 12:51 AM
plasma or water jet??? hutch82 CNC Plasma and Waterjet Machines 8 01-29-2007 09:40 PM
plasma water tank snaggletto CNC Plasma and Waterjet Machines 41 06-17-2006 08:04 AM
