Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Plasma and Waterjet Machines > Plasma, EDM and other similar machine Project Log
Plasma, EDM and other similar machine Project Log Post your building log of your machine here for all to discuss.
Old 03-10-2008, 08:04 AM
lamicron is on a distinguished road
4 x8 Plasma and Router
We started this second machine with some changes , and have to make it in one month. The works began the 14th of feb.
Will use a waterbed, 1160 oz/in motors for X and Y and 495 for Z. Rails and blocks from Hiwin for the Y and Z, and Roton screw for the Z. gear and rack for X and Y.
ID:	55210   Click image for larger version
ID:	55211   Click image for larger version
ID:	55212   Click image for larger version
Old 03-10-2008, 10:54 AM
Mongkol is on a distinguished road
Smile Plasma table,
Hi Luis,
The first plasma machine, Did you sell it already? Do you use THC for the first machine? I expect your experience will make the second machine excellently.
Mongkol
Old 03-10-2008, 09:43 PM
Hi Mongkol, yes I sold the first one and no, i didnot use the thc for that one, but will use for this one. some changes also in the gantry.
ID:	55268   Click image for larger version
ID:	55269   Click image for larger version
ID:	55270   Click image for larger version
Old 03-17-2008, 08:28 PM
hey Millman, or any other expert, need some help',
Today i was starting the first plasma table I made, I have a Thermal dynamics 50 Pack. I had cut two parts and in the tjhird the mouse got stucked. also the keyboard. I had to restart the PC,
Tryed again and get the same results, maybe the HF?? I have the machine and the plasma grounded at different points.. Any clues?
Luis
Old 03-25-2008, 08:18 AM
new pics
We have painted and installed some of the rails, now installing motors,
ID:	56354   Click image for larger version
ID:	56355   Click image for larger version
ID:	56356   Click image for larger version
ID:	56358   Click image for larger version
Old 03-25-2008, 08:57 AM
Med-Pac is on a distinguished road
Nice machine, congrats on a great job.
Mike
Old 03-26-2008, 07:18 PM
millman52's Avatar
millman52 is on a distinguished road
Luis
Luis, sorry I haven't been on for a few days. Have you got your computer "freezing" problem figured out? If so what was causing it?
Your new build looks very good.
My guess on the screen lock problems id noise somehow finding it's way back to the computer. Usually from common ground(s)
Typically you should have your plasma machine grounded to a seperate ground rod than your AC power supply. you should also have your plasma work ground directly to the piece of metal you are cutting. NOT to the machine bed or machine frame.
Neil
If it works.....Don't fix it!
Old 03-26-2008, 09:20 PM
Yes, I found that, I put a separate rod for the plasma ,
The problem was in the pc grounded. Fixed now ,Thanks
About the :
" you should also have your plasma work ground directly to the piece of metal you are cutting. NOT to the machine bed or machine frame."
I use the ground to the slats where the work is cut, not directly to the work, is ths ok?
Old 03-27-2008, 07:18 AM
millman52's Avatar
It is recomended that the work ground go directly on the sheet being cut. Most slats are "drop in" & don't have a secure metal to metal contact surface.
It will probably work, hooked to the slats, most of the time. You are however leaving that chance of loosing ground & causing problems.
Neil
Old 04-04-2008, 10:51 PM
Almost finish, have to install the tHC 300, andf get the slats for the waterbed,
ID:	56979   Click image for larger version
ID:	56980   Click image for larger version
ID:	56981   Click image for larger version
  #11   Ban this user!
Old 04-04-2008, 10:55 PM
Smile Plasma machine
Luis,
It's a nice machine.
Mongkol
  #12   Ban this user!
Old 04-12-2008, 11:14 PM
Already finish
Last photos from my cnc plasma
ID:	57524   Click image for larger version
ID:	57525   Click image for larger version
ID:	57526   Click image for larger version
Newbie- Does anyone own a EZ Router Machine? Plasma or Router. sngatlanta Commercial CNC Wood Routers 30 04-11-2008 11:48 AM
plasma/router ? ata Plasma, EDM and other similar machine Project Log 0 10-18-2007 09:04 PM
DIY plasma/router terrydullaway Plasma, EDM and other similar machine Project Log 25 10-10-2007 03:22 PM
Plasma-vs-Router Blacksunshine DIY-CNC Router Table Machines 5 09-28-2006 11:12 AM
CNC Router / Plasma amdmonster DIY-CNC Router Table Machines 3 11-28-2005 04:37 PM
