Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Plasma and Waterjet Machines > Plasma, EDM and other similar machine Project Log
Plasma, EDM and other similar machine Project Log Post your building log of your machine here for all to discuss.
Old 02-19-2008, 05:42 PM
wiwoods is on a distinguished road
Question on torch height
I have been following along and gleaning a wealth of knowledge while building my small 3ft X 4 ft table. I am currently using 3/8 XL belt drive for the X and Y and ball screw for the Z axis.
I hope to post some pictures as soon as I get things neatened up but i have it moving in the x and y axis quite nicely.
The question I have is for a temporary solution to torch height, would it be better to install a home switch on the z axis at zero height, or implement some type of feeler switch to sense home based on touching the material?? Any suggestions examples? With a "feeler" how would one treat this in mach 3?
I also failed to factor in a number of items when estimating cost, like the small lathe to help produce some of the parts, and oh by the way the Taig mini mill. Oh and did I mention that it would really be cool to adapt them to CNC! I guess that can wait until the plasma table is done! Wouldn't have missed it for the world though in terms of knowledge gained in building this up!
Old 02-19-2008, 06:20 PM
millman52's Avatar
millman52 is on a distinguished road
The home switch for your Z axis is just that. a referance point to a specific distance of your torch tip to table surface. About all you can do with a feeler switch (floating head switch) is let it touch the sheet you are cutting before each pierce. Then mach will pull the torch tip off the sheet a specified amount.
I borrowed a picture from www.CancCNC.com to post for you to give you some idea of a floating (feeler) switch.
This particular one looks like it is designed to hold a hand torch. Build what ever you need to fit your torch. But this should give you the general idea.
Name:	CNC Floating head switch.jpg‎
If it works.....Don't fix it!
Torch Height Control Rxe CNC Plasma and Waterjet Machines 7 04-07-2010 07:09 AM
DIY torch height control mjp CNC Plasma and Waterjet Machines 34 12-20-2009 03:57 AM
Torch Height Control luther Plasma, EDM and other similar machine Project Log 4 07-12-2007 04:51 PM
Torch Height Control / Capacitive Height Control ahlbebuck Open Source Controller Boards 0 11-27-2006 02:32 PM
TPI for Torch height axis edwardpic CNC Plasma and Waterjet Machines 3 08-30-2006 09:29 AM
