Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Plasma and Waterjet Machines > Plasma, EDM and other similar machine Project Log
Plasma, EDM and other similar machine Project Log Post your building log of your machine here for all to discuss.
Old 06-29-2004, 02:10 AM
Apples's Avatar
Apples is on a distinguished road
Started to build my plasma table.
I have started to build my plasma table. I have used 65x65x2.5mm galvanised s.h.s. The size of the table is 3.5meters x 2meters. It is huge! It will be able to cut a full sized sheet of material, which is 3mx1.5m.
I will take some photo's and post them up. The basic frame has just about been completed. I have 6 castor wheels on it to move it around, four of which are in the corners and are locking wheels.
Old 06-29-2004, 02:15 AM
ynneb's Avatar
Moderator
ynneb is on a distinguished road
I can hardy wait for the pictures.
Old 06-29-2004, 08:45 AM
InventIt is on a distinguished road
Yeh, lets see some pics!!!
Old 06-30-2004, 02:46 AM
Apples's Avatar
here are some pics
Here are some pics of the table.
3500x2000x900mm.
Old 06-30-2004, 02:51 AM
Apples's Avatar
pics won't upload
how do i upload a pic?
i just went to browse and select the pic and submit reply and thats all that happened.
Old 06-30-2004, 09:20 AM
is your pic file too big? Try it again.
Old 07-01-2004, 04:18 AM
Apples's Avatar
here is a pic
Name:	table looking out garage door.jpg‎
Old 07-01-2004, 05:07 AM
svenakela is on a distinguished road
I like your welding helmet.
-Sven
Old 07-01-2004, 05:52 AM
ynneb's Avatar
Moderator
I dont know how plasma cutters work. But I was wondering if there was going to be a problem with cutting through those cross beams. Would it be an idea to have strips of steel in turned sideways in the middle. If you had slots at each end you could replace the strips as needed.
Maybe plasma cutting isnt like oxy cutting!
Old 07-01-2004, 09:12 AM
WOW! That's a Monster! Looks good.
Old 07-01-2004, 06:48 PM
IJ. IJ. is offline
Gold Member
IJ. is on a distinguished road
Re: Started to build my plasma table.
Originally posted by Apples
It is huge!
Understatement Apples !
Well done so far I'll follow this one with interest.
(said it before and I'll say it yet again I really admire you guys that scratch build a machine as my recent retrofit has been an enormous amount of work/thought to complete)
  #12   Ban this user!
Old 07-02-2004, 01:57 AM
Apples's Avatar
i am going to have 4 lengths of angle iron welded onto those cross braces and then every 2inches or so cut a slot into the angle and insert some flat steel. The flat steel i will use would have to be around 75mm or 3" wide. that means that i should have 75mm of clearance between the bottom of my sheet of steel that i am cutting and those cross braces. Hopefully this is enough clearance.
Yeah that is a pretty awesome looking welding helmet, it is an automatic darkening one too.!
Newbie - To build or not to build Router/Plasma Table dfranks CNC Plasma and Waterjet Machines 10 04-08-2011 12:16 AM
I need to Build a 8’ x 30’ cnc plasma table asil CNC Plasma and Waterjet Machines 31 08-10-2005 10:05 AM
Need help finalizing plan for CNC Plasma table David Bord CNC Plasma and Waterjet Machines 6 05-25-2005 08:16 PM
CNC Plasma table plans krazycnc CNC Plasma and Waterjet Machines 4 05-05-2005 10:51 PM
My plasma table design m_c CNC Plasma and Waterjet Machines 16 07-24-2004 02:01 PM
