Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Plasma and Waterjet Machines > Plasma, EDM and other similar machine Project Log
Plasma, EDM and other similar machine Project Log Post your building log of your machine here for all to discuss.
Old 11-11-2007, 11:01 PM
lamicron is on a distinguished road
Wiring the step motors
I have the 495 oz package from keling, i have two motors for the gantry, one of these should go with the rotation inverted , how do I have to wire it? The two motors are wired to the same x axis?
Luis
Old 11-14-2007, 10:21 AM
millman52's Avatar
millman52 is on a distinguished road
I'm sure someone else can straighten you out on this. My understanding is, you have to have them wired in a master/slave arrangement using (2) stepper controllers.
If it works.....Don't fix it!
Old 11-14-2007, 11:48 AM
pminmo's Avatar
pminmo is on a distinguished road
If you set it up via software, then the 2nd motor is setup as a slave to the X axis. In the software setup invert the dir pin on the setup.
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 11-14-2007, 08:14 PM
Thanks, but dont understand, I know i can change the rotation in the software, but one has to go backwards, then it should be wire inverted, isnt it?
Old 11-17-2007, 10:27 PM
millman52's Avatar
My Steppers came pre wired with plugs on them. They were all wired the same. I changed direction in Mach3 ports & pins. When you changd direction in the software it esentially does the same thing. Reverses polarity.
Old 11-18-2007, 07:37 AM
Thanks millman, but I think I have to wire the 4th motor to the A input, isn't it?
Old 11-18-2007, 01:51 PM
pminmo's Avatar
Yes wire the 4th axis as A. Setup the A ports and pins as wired. You will the control the rotation of the 4th axis in relation to the axis you slave it too. So you set the DIR pin of the A axis state to either low true or high true to get it to rotate the direction you need it verses the slaved axis. No motor wiring changes needed. Before you mechanically connect the slaved axis motors, do the software setup and test it.
Old 11-18-2007, 03:27 PM
millman52's Avatar
Definitely Test the rotation! Even the 495 steppers especially through reduction could twist your gantry out of alignment. Or cause damage elswhere.
Old 11-18-2007, 05:56 PM
I received the same info from Zoltan, I'll go that way.
Of course i'll try it before gear it..... i'm really scary about it!!!
Thanks amigos!
Step Motor Driver and Power Supply Wiring mcan Open Source Controller Boards 3 01-19-2007 05:22 AM
I got the step motors so what's next rbocaz CNC Plasma and Waterjet Machines 2 08-14-2006 12:04 PM
Step-Syn Motors lilwen Stepper Motors and Drives 4 07-02-2006 10:17 PM
Step sync motor wiring sailinon Stepper Motors and Drives 4 11-12-2005 01:17 AM
Before buy the Step Motors. samsagaz Stepper Motors and Drives 3 03-28-2005 06:50 PM
