| Plasma, EDM and other similar machine Project Log Post your building log of your machine here for all to discuss. |
I recently finished my CNC router/plasma table. I have been playing with the router for a while and am ready to finish the build by switching it over to handle my plasma cutter. I will be doing art type cuts in sheet metal, so do not need a absolutly perfect cut. Also I probably wont have that many small detail pierces and all stock will be flat sheet. I am wondering how sloppy it will be to not use a THC? I am using a laptop currently as the controller so no 2nd parallel port. For initial layout I want to keep it as simple as possible so I am hoping i wont need a THC off the bat. So before i go spending any more money or resetting the table and tool holder for the conversion I thought I would ask for some feedback from anyone with experience. Thanks a ton. btw here is the table build log, New router build I can get up to 500ipm on the y, maybe 70 on the x and 12 on the z. I hope 70 is enough for 16ga. |
| Post # 48 at this LINK has pictures of the torch mount. Other locations in the thread show more construction of the mount, as well as very satisfactory and accurate cuts made with this system. |
| thanks for the link. That will help allot. Feels much better having some guidence on it from peopel who have done it rather than just guessing and hoping as usual ![]() I dig the floating head, I will see what i can come up with. I also dig the chain drive, I had seen beetmans table, hadnt seen any other chain drives. at 40-70ipm on my X i am thinking of a redesign. My wiring harness is already set for the x motor on the end plate, so another rack and pinion is out, i was thinking of maybe a double start acme insteadof the ballscrew (which is kinda fine pitched) but chain might do nicely too, only thing i might worry about is back lash when in router mode. was worried abotu backlash too on the Y in router mode, but the double rack and fully engaged teeth didnt end up having any problem thankfully. have you tried yours with a router yet? any noticable chatter from the chain having to fight the cutting forces? thanks -Dave |
| No, I have not used my machine with a router. The floating head, has 4 transfer bearings that roll on the surface of the material being cut. The idea came from the plans by Mike Laws, that have a link earlier in my build log. Beetman & I both started our chain driven tables about the same time. Others were also built by Massajamesb, as well as Smilewizard who switched his from belt drive to chain with satisfactory results. |
| oops forgot to update this thread ![]() i really liked the floating head idea, but being rather ughh...lazy I figured I would start with a solid head first just to get up and running fast I also decided I would experiment with a mechnical trigger activation mechanism before popping into my case and voiding my warrenty here is the torch mount / trigger activator i ended up coming up from trial and error and from others ideas on teh board http://cnczone.com/forums/showpost.p...9&postcount=13 the idea for the trigger mechanical thing is from meincer's build http://cnczone.com/forums/showthread.php?t=31346 I havent used it a ton yet, just had to tear it all down for winter ![]() I have had the tip end up dragging as the metal peels up or bows from teh heat, doesnt drag hard enough to move the work piece yet (just have a weight on it to keep it put so far) I may add in a roller berign design around the cut tip to maybe push down on the metal and keep torch solid mount if need be. the thicker the stuff your cutting the less warp so still might not be necessary for 11ga + will see , it will tell me if its a bad design in time |
| thanks, yeah has been lotso work but fun as hell ![]() couple things i had to make work arounds for and couple things i had to ditch and rework, built it for experience/fun so invaluable learning really. I have a hypertherm powermax 380, 110v, i belive they are not a HF start. I did use properly shielded wire for teh steppers, i have not experienced any lost steps or drunk motors due to emf. (mcmaster part numbers in the receipts.pdf in build log) i cheaped out for my limit switch wires and used a foil shielded audio wire...they did pick up noise even from the ac power line going to the router head so I have scrapped limit switchs for now |
