| Plasma, EDM and other similar machine Project Log Post your building log of your machine here for all to discuss. |
| How do I know? this is going to be a trainwreck, i'm warning you guys now. I'm not an engineer, (just an architect & welder) so I've decided to ask for some help. I've been looking at torchmate machines for a while now, but $8000 is a big chunk for me. I've seen all these home built projects and I'm eager to start one myself. I'm hoping to build a 4'X8' table, and the table and gantry aren't an issue, and now that I see some pictures, the bearing system isn't bad either. The questions I do have relate to the motor drive mechanism and computer control. I've seen gear drives, belt drives and screw drives. which one is best, and which one is easiest? Once i match up a motor to the drive, how does the computer know how fast, and the distance of travel for the torch head? Or is that something that's programmed in once everything is built and the limits are established? I run autocad all day at work. at home I run a mac. would I have to run another computer with the machine, and a the program and all? Where would I be able to find all the parts, motors, computer parts and all for it? any help you guys could give me would be much appreciated, I've read through some other posts and everyone seems very helpful. |
| I feel for a large table machine gear rack is the way to go. As far as the control goes do some searches on "Mach 3".
__________________ On all equipment there are 2 levers... Lever "A", and Lever F'in "B" |
| Most modern stepper motors have 200 "steps" in one revolution of the motor shaft. You will have to do a little math to find out how many revolutions the motor makes to move one inch. This will involve compensating for any gear reduction, drive gear pitch and size, microstepping, etc. You will then tell your software controller how fast you want it to move, either in a setup table, or in your G code. Motors- www.kelinginc.net www.homeshopcnc.com Drivers- www.kelinginc.net www.geckodrive.com gear rack and spur gear-www.mcmaster.com various parts, motors, pulleys, belts, etc.- http://www.stores.ebay.com/HUBBARD-C...Q3amesstQQtZkm complete electronics packages and systems- www.candcnc.com CAM software- www.sheetcam.com controller software- Turbocnc- www.dakeng.com Quickstep- http://www.cpwojcik.home.att.net/Qst...step_CNCx.html Mach- www.artofcnc.com Hope all that helps!
__________________ (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) "If the women don't find you handsome, they should at least find you handy" -RedGreen show. |
| holy lots of information. thanks, i'll have to spend some time going over everything |
A little more information to add to Massajamesb's great answer. Regarding your question quoted above, the computer uses a control program to read a machine code language, which is based on the CAD drawing of the part to be cut. Sequence would sort of be: 1 draw the part in CAD program. 2 Convert the DXF drawing to machine code using a CAM program. 3 Control prog. reads code & sends signals to motors, torch switch, relays or other mechanical devices. It's the code then, that tells the torch where to go, at what speed, & what to do. |
