Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Plasma and Waterjet Machines > Plasma, EDM and other similar machine Project Log
Plasma, EDM and other similar machine Project Log Post your building log of your machine here for all to discuss.
Old 07-21-2007, 03:41 PM
loopy251 is on a distinguished road
Smile ## Help anyone##Win CNC Problem
I am having a problem in WIN CNC with my y axis win cnc error Low limmit on y.{Soft limit's off or on makes no difference} X and Z are working fine but the machine does not move on the y axis just sits there and makes growling noises as if you were trying to force the Gantry past the end of the table stop. Changed the lead wire to the stepper and replaced it with the x-axis wire and it moves around fine.Anyone have any ideas im not sure if this is a setting problem or if my IO controller card is screwed. Oh i also uninstalled and re-installed the controlling software and removed and reinstalled the controller card with no success.
Thanks anyhelp of ideas would be appreciated.
Old 07-23-2007, 07:09 AM
cut more is on a distinguished road
Hello loopy,
long time no talk,
It sounds like your limit switch may be staying on. Is the red light for the limit lit on the screen? I also had a problem with mine where the connector that plugs on the motor had begun to melt and sometimes the motor would do what you are describing or it would stop in the middle of program. Look at the connector on the motor to see if it has a dark spot or any signs of overheating.
Hope this helps.
Cutmore
has anyone else run into this problem austin.mn CNCzone Club House 0 05-31-2007 10:21 PM
G52 Problem j-radkemachine Haas Mills 1 04-19-2007 06:09 PM
dro problem Dar Bridgeport and Hardinge Mills 2 04-05-2007 09:31 AM
VF0 problem Brendan Haas Mills 6 01-16-2007 12:42 AM
Problem impact Xylotex 1 03-12-2006 01:53 PM
