Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Plasma and Waterjet Machines > Plasma, EDM and other similar machine Project Log
Plasma, EDM and other similar machine Project Log Post your building log of your machine here for all to discuss.
Old 02-05-2007, 10:01 PM
scorpion is on a distinguished road
Plasma Cutting Aluminum
Currently running a Powermax 1000 and would like to cut 3/8" aluminum. has anyone tried this? I'm going to cut a couple of samples to see what quality I can get but for the most part it doesn't matter since the part will be machined after it's cut.
Material will be 6061, 3/8" plate.
Thanks!
Old 02-05-2007, 10:30 PM
Chris64 is on a distinguished road
I've plasma cut 1/4 alum. It works fine, but the finish isn't as nice as steel. Not that you're probably building an airplane...but I've read some type of FAA regulation that required at least 1/8 milling after plasma because it leaves a lot of microscopic cracks. this may or may not matter for your application.
Old 02-06-2007, 12:01 AM
Interesting. I cut some thinner stuff a ways back and my impression of it was that that it tears the aluminum more than it cuts it. Guess that was partially true.
Good to know though. It's not areo-space but I will leave more than 1/8th for machining and finish quality. Thanks for the info.
Old 02-12-2007, 09:22 AM
cut more is on a distinguished road
Plasma cutting Aluminum
Scorpion,
I run the powermax 1000 also. I have cut 1/2" aluminum with mine, Also 1/2" ss, 1/2" mild steel. All this with the finecut tips. The edge will not be like steel but it is do-able.
Cutmore
Old 02-12-2007, 12:29 PM
Originally Posted by cut more View Post
Scorpion,
Cutmore
Can you give me approx settings for IPM, Voltage, and amps for 1/2" Al? It would give me an approx starting place and possibly save me a tip. I had planned on starting where I do for steel but with a little higher voltage setting but that was a pure guess.
Thanks.
Old 02-12-2007, 01:07 PM
Scorpion,
I turned my athc off, pierce was ~1.5 sec. Amperage was 60, speed ~12 Ipm for straight and I think 6 or 8 ipm. circles. I will check when I get home & let you know exact speeds tomorrow.
Cutmore
Looking for some Plasma Cutting ArcadEd Employment Opportunity 4 05-09-2006 09:26 AM
K2 cnc Aluminum Cutting Ed Williams General Metalwork Discussion 0 03-16-2006 01:38 AM
Plasma cutting mdf. ynneb CNC Plasma and Waterjet Machines 8 11-05-2004 08:56 PM
plasma cutting? anyone using it? rmacguiver CNC Plasma and Waterjet Machines 11 11-05-2004 09:31 AM
Aluminum Cutting Tazzer DIY-CNC Router Table Machines 5 07-29-2003 01:09 AM
