Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Plasma and Waterjet Machines > Plasma, EDM and other similar machine Project Log
Plasma, EDM and other similar machine Project Log Post your building log of your machine here for all to discuss.
Old 01-24-2007, 12:46 PM
cut more is on a distinguished road
Sources for gear rack
Guys,
I am looking for a supplier for the gear rack practical cnc used or something close. The rack is 24 pitch 1/4" wide but it is about 1-1/2" tall. Mcmaster sells24 pitch rack but it is only 1/4 x 1/4.
Thanks for the help.
P.S. I tried the search here on cnczone and it seems hard to find things maybe just me.
Old 01-24-2007, 12:58 PM
keebler303 is on a distinguished road
this link is from someone on the zone.
http://www.stdsteel.com/
could you use the rack mcmaster has and either bolt or weld bar stock to it to get your desired size?
Matt
Old 01-24-2007, 03:05 PM
Moderator
JerryFlyGuy is on a distinguished road
check out Bostongear.com and search for Marting sprockets [ they also do gearing] Or grab your phone book, look up " Bearing supply". Pick out a company or two and give them a shout. They will most likely have sources that the rest of us might not be able to easily find.
I've also heard people talk of the great deal's they get from various specific suppliers. I find that calling my local supply is generally cheaper in the long run [for simple stuff like this] than getting something shipped in from across country for a few bucks less. There's value in shopping locally. It's also not uncommon to get the exactly same stuff from the local supply that you'd get from 1000miles away, made in the same factory etc..
FWIW
Jerry
JerryFlyGuy
The more I know... the more I realize I don't
Old 01-30-2007, 10:29 AM
Thank you for the tips guys I will look into your suggestions.
Thank you,
Cutmore
Old 01-30-2007, 04:44 PM
millman52's Avatar
millman52 is on a distinguished road
Originally Posted by cut more View Post
Guys,
Quality Transmission Components has a banner ad on CNC Zone here is a listing of what they have in 24 pitch 20 degree pressure angle. Looks like they have 5/16 X 5/16 & 5/16 X 5/8
Catalog Number
Diametral
Stock Length
Face Width
Height
Pitch Height
Brass
Steel
Pitch
(in.) A
B
C
D
QG-R24-10X10-03B
QG-R24-10X10-03S
24
3
0.312
0.312
.270/.267
QG-R24-10X10-06B
QG-R24-10X10-06S
24
6
0.312
0.312
.270/.267
QG-R24-10X10-12B
QG-R24-10X10-12S
24
12
0.312
0.312
.270/.267
QG-R24-10X20-03B
QG-R24-10X20-03S
24
3
0.312
0.625
.583/.580
QG-R24-10X20-06B
QG-R24-10X20-06S
24
6
0.312
0.625
.583/.580
QG-R24-10X20-12B
QG-R24-10X20-12S
24
12
0.312
0.625
.583/.580
If it works.....Don't fix it!
Old 01-31-2007, 07:41 AM
Thank you Millman,
This is close to what I was looking for. I just need to figure out if the rack I have is 20 degree or 14-1/2 degree.
Cutmore
Spur Gear / Gear Rack ckrantz Linear and Rotary Motion 12 12-07-2006 12:06 AM
Gear Rack Sources-10ft. utahnorton Linear and Rotary Motion 8 05-17-2006 10:39 PM
rack gear mniadna DIY-CNC Router Table Machines 6 01-19-2005 10:06 AM
question on gear rack wired DIY-CNC Router Table Machines 7 01-08-2005 02:37 PM
Cover for gear rack? samualt DIY-CNC Router Table Machines 8 02-24-2004 09:22 AM
